Old 03-27-2016, 02:40 PM
Che70velle's Avatar
Default Car covers
What cover for your car, do you guys recommend? Maker or fabric types?
I've found many different types, and don't know where to start.
Thanks Dad!!
Old 03-27-2016, 04:49 PM
minendrews68 minendrews68 is offline
This is a little different, but my wife and I got a set of bed sheets from Berkshire Blankets. These are some of the softest, nicest, most comfortable sheets i've ever seen!!! I'm going to call them and see if I can get two flat sheets and have my daughter sew them together.
Old 03-27-2016, 06:22 PM
Build-It-Break-it's Avatar
Start with where you'll be storing it. Indoors, outdoors, controlled temp environment,rain, snow, sunshine, wind etc. Then choose one that fits those conditions and your budget.
Ahmad B
Old 03-27-2016, 10:16 PM
sd67 sd67 is offline
Check out California Car covers, really like mine for my 67 Camaro:
www.calcarcover.com
Old 03-28-2016, 07:46 AM
Neil B Neil B is offline
I use the Superweave Cover from California Car Cover. It works great both indoor and outdoor. It is lightweight, easy to handle, folds up small, can be machine washed, and is near water proof. The only drawback to it is that it does not provide much 'cushion' against dings etc. (if the car is kept in a high traffic area). I've tried thicker covers but I always come back to this one...
Superweave Car Cover
Providing the premium in outdoor, all-weather storage protection; Superweave is our most UV resistant, water resistant and weather resistant car cover. The versatile Superweave material features unsurpassed moisture, dust and pollutant protection. The encapsulation technology goes INSIDE the fabric, around the fibers, resulting in a silky smooth finish that glides over fine paint finishes. Our Superweave Car Cover fabric is also dust-proof so it will keep your vehicle clean whether it is stored indoors or out. It still remains exceptionally breathable, allowing moisture, condensation and heat to easily escape from under the car cover. When rain hits the cover it simply runs right off and any moisture left on the cover will usually dry in about 10 minutes. Its unique lightweight design also enables it to fold up to 1/3 the size of your typical outdoor car cover (about the size of a sweatshirt or jacket), but does not take away from its ability to protect your automobile's finish. The material is also easy to care for because it is the only fabric that is washer and dryer safe. 4-year limited warranty. The Superweave car cover can be ordered in one or two-tone color combinations. Available in Black, Bright Blue, Grey, Sky Blue, Green, Red, Taupe and Yellow. Grey is the most popular for outdoor use and will reflect the UV rays of the sun the best. Bright colored Superweaves may fade in direct sunlight but do look great for indoor use. Motorcycle covers are also available in the Superweave material; in Black, Grey and Taupe - single color designs only. Made in the U.S.A.
From $259.99
More Info
5 out of 5 stars. Read reviews. 5.0 •Lightweight, Durable All-Weather Protection
•Our Most UV, Water & Weather Resistant Material
•Folds to 1/3 the Size of a Typical Outdoor Cover
•4 Year Warranty
Old 03-28-2016, 10:49 AM
Che70velle's Avatar
Thanks for the replies fellers. The car will be kept inside, on my lift. Never left out in weather. I pretty much need the cover to basically keep dust off. I'm looking for fabric that won't harm paint over long term usage. Appreciate the recommendations!
Thanks Dad!!
Old 03-28-2016, 12:39 PM
ironworks's Avatar
We live in a pretty dusty part of California. I have found the plastic car covers with elastic seem to work the best. They are clear and like 20 bucks each. We keep them in the shop and put them over the car and when they are dirty just get a new one and throw the other away. The fabric ones breath and also let the dust through or when you remove the cover all the dust just falls through.
For long term storage we us the soft micro fiber kind of cover with the plastic one on top of that.
Old 03-28-2016, 03:20 PM
turnhard turnhard is offline
Where do you get the plastic car covers? Kevin
Old 03-28-2016, 04:36 PM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default plastic
What Kevin said .. ??
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 03-28-2016, 05:16 PM
ironworks's Avatar
Steve
I will check with my wife, She was gonna put them on our website.
