Old 03-27-2016, 11:32 AM
Stovebolter's Avatar
Stovebolter Stovebolter is offline
Brett has responded stating he had no problem swapping out my lowers and suggested that I speak with a lead tech (Rodney) about the change. I'll give them a call sometime early next week. Thanks Bret.
David
468 BBC, TH400, Moser 9" floater, True Forged Competitions 18x9.5 18x12, Kore 3 C6 ZO6 calipers 14" & 13" rotors, Ride Tech True Turn, Ride Tech Air TQ's, Torque Arm with Watts link, Moser CT Full Floater 9" with locker.
Old 03-28-2016, 08:31 AM
paulk68 paulk68 is offline
does anyone have pictures of the two different style A-Arms I would like to make sure I have the new style as I really do not want to run into any more issues.
Old 03-28-2016, 03:27 PM
Paul, when did you purchase yours? I believe they made a change in late 2013 that corrected the issue I'm having. And not everyone with the first production run is having the issue I'm having. May be a difference in cars as odd as that sounds.
Does your upper cross shaft have the adjustable aluminum slugs in it for caster angle adjustment? If so, you have the latest design and should be okay.
Old 03-28-2016, 03:52 PM
Rod P's Avatar
Rod P Rod P is offline
new style
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 03-28-2016, 04:07 PM
Originally Posted by Rod P View Post
new style
Thanks guys, yes I have the newer version with the slugs.
Old 03-28-2016, 04:53 PM
dhutton dhutton is offline
I thought the issue was the lower control arms. Did they change both at the same time?
I just bought a used Level 2 and Tru-Turn setup so I'm trying to figure out which lower arms I have. I'm not going to run a 275 front tire so I am not too worried but would like to know.
Old 03-28-2016, 05:33 PM
We were just helping him determine what production run he had. As far as I know the 2nd production run included their newer uppers with the adjustable caster slugs.
Old 03-29-2016, 01:05 PM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Be sure to post up the information you come up with after you get your arms swapped
Old 04-02-2016, 08:34 PM
The new control arms corrected my issue. My wheels are now centered in the wheel opening and the tires just kiss the sway bar equal amounts....nothing I can't correct with the addition of stops. No where near the wheels now. Thanks Ridetech!
Old 04-02-2016, 08:47 PM
randy randy is offline
Your car is that slammed and you were complaining about turning radius and rubbing? lol
Are you going to bring up the front some?
Edit..... I think you have air ride
