Go Back   Lateral-g Forums > Technical Discussions > How To's, Tips, and Tricks
Old 04-06-2016, 12:37 PM
David Pozzi's Avatar
I'm using a cheap siphon sand blast gun in mine. I have 170 psi shop air available but I found the media flow is reduced at that pressure. The pressure backs up in the gun. I use a regulator to around 90 psi and get a better media flow.
Drilling out the air jet can cause so much air to flow, you don't get as much suction on the media hose. I put a vacuum gauge on mine to set pressure.
http://www.PozziRacing.com
