Old 04-21-2016, 05:26 PM
Shiner's Avatar
Shiner Shiner is offline
Default AFR Titon Dual Plane Review
Any thoughts on this intake?
http://www.jegs.com/i/AFR-Airflow-Re.../4804/10002/-1
Is it worth changing out my aluminum RPM Air Gap copy for this?
I think a plus is no more silicones etc and the plastic for air charge temps
1970 Chevelle SS
408 Forged LSX, LSA Blower, 4L80E, Ridetech HQ, Baer Brakes, Weld S71b
1997 Dodge Viper GTS
Heads, Cam, Bolt On's, BBS Wheels, Moton Suspension
Old 04-21-2016, 07:16 PM
JKnight JKnight is offline
There's still some silicone between the upper "spider" portion and the baseplate. Or am I misunderstanding what you mean by silicones? But the thermal properties are a plus.
Old 04-21-2016, 07:22 PM
Shiner's Avatar
I meant primarily the China walls
1970 Chevelle SS
Old 04-21-2016, 08:41 PM
Che70velle's Avatar
If I were building another small block for the street, I'd go with this unit. I especially like the fact that you can pull the intake runners, without pulling the dizzy, or messing with the coolant. The weight loss and thermal properties are a bonus.
Thanks Dad!!
Old 04-22-2016, 08:12 AM
nicks67ca nicks67ca is offline
I have the Titan TXR version (not installed yet). I'm moving away from the Victor Jr. (which has served me well). I think the change will be worth it just from what have been reading.
Old 04-27-2016, 03:04 PM
z28cp z28cp is offline
I have one of these intakes on a 406, not running yet. It does still use silicone on the china walls.
