Old 04-26-2016, 05:03 PM
toddoky toddoky is offline
Thats the same one I have, it's made for the LS it mounts to the exhaust bolts so no need to remove the intake. Expensive but the tilt adjusts really easy.
I'be used it in that manner and also by removing the tilt mechanism from the tube frame and attaching it directly to the valley cover on top of the engine.
Old 04-27-2016, 07:07 PM
Nine Ball Nine Ball is offline
The type that bolt onto the valley cover are better, because you can pull or drop an entire engine without removing the hood. I used the one from Quick Time Performance, and it balanced nicely with the front belt accessories and clutch/flywheel installed. Got it from Summit.
Founder, LS1Tech.com
1969 Camaro SS Convertible | 1970 Chevelle SS 454 | 2006 Viper Coupe | 2014 Viper TA | 2014 Camaro SS 1LE
Online Garage: www.fquick.com/NineBall
Old 05-21-2016, 10:55 AM
Nine Ball, I used the one I have because I didn't want to remove the supercharger. I would have been much happier to use one like you did if the intake was coming off.
Old 07-31-2016, 07:16 AM
paulk68 paulk68 is offline
so I got the valley cover plate since i am not doing a ton of swaps but it did not come with any hardware. can i just re use the bolts from the intake when i take it off? are they strong enough to hold the engine?
thanks
Old 07-31-2016, 05:57 PM
Musclerodz's Avatar
macs is by far the best one i have found.
Mike Redpath
Musclerodz & Customz
facebook page
