Old 04-10-2016, 06:55 PM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
Originally Posted by 69lsvert View Post
Came by and seen the car. Looked awesome but I have to say it was in the coldest place on the property. Hope today's better for you.
It was cold as hell in there on Saturday - Sunday wasn't too much better at least the wind died down.
Too be honest I was barely by my car all weekend - I was walking around and sitting out in the stands in the sun for most of the day.
I did manage to snag a trophy - can't complain with all the work that I've done to the car over the last few months:
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 04-11-2016, 02:37 AM
69lsvert 69lsvert is offline
Congratulations, all that hard work paid off.
Old 04-16-2016, 02:27 PM
Ever since I put those Holley valve covers on - I have been having problems with losing oil/a huge cloud of smoke billowing out of the car on cold start up.
I did some research and the Holley covers like to suck oil through the drivers side valve cover right into the blower.
I am sure on a N/A setup - they would work great, but after loosing a quart of oil in a weekend - I had enough.
I ripped them off and ordered a set of LS9 valve covers.
These are built for boost - and give off the same look of no coil pack brackets.
For now I put the stock covers back on - and have not had an issue. No oil consumption, no huge clouds of white smoke on startup, etc.
I got the covers a few days ago - and have painted them black like the Holley covers.
I'll put them on the car after they cure for a couple days.
I also ordered a catch can - and will install that along with the covers.
This should resolve my oil consumption issues - and give me the look that I am after.
At the end of the month I will be towing the car up to VA for the Wannagofast 1/2 mile event up there - my shirt just came in today.
Old 04-16-2016, 07:54 PM
Che70velle's Avatar
I read your thread over on Tech, about your issues. I'm glad you got this straightened out. The 1/2 mile stuff sounds like fun!
Thanks Dad!!
Old 04-18-2016, 06:54 PM
These new covers should help out - after losing that quart of oil in 60 miles or so - I had enough and went back to stock.
Sucks having to go through different parts to resolve your issues.
One plus side is that the LS9 covers have the newer PCV vents on them -and allows the E-Force PCV valves to snap and lock on to them.
The Holleys and LS2 covers didn't allow that fitting to work - so I had to remove them. This will make for a more clean setup.
Old 04-19-2016, 02:00 PM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Bonecrusher, I just read this whole thread should of listed it as 05 vette build, G8, SS and P/u good stuff and I can say I like it! your cheap like me which isn't bad. you made some good choices your door opener is same one I have in my shop I built in '12 - had to use that because of my ceiling design, you mentioned a quote of 900$ installed mine was $1400 but it included a 8'x16' door that was insulated as well - my installer said he had never installed one before and he said they were high guess if you call'em up and that's what you get charged for them-crazy. I LOL on the picture with you finger at the old opener. Ill keep my eyes peeled for you on HRPT I've been many times although I doubt your coming this year- keep up the good work man car is looking and running great!
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 04-22-2016, 12:02 PM
ZMAN - Thanks for reading! Yeah I'm pretty cheap in regards to fixing stuff around the house and the cars as I am a pretty big DIY'r.
That opener wasn't too bad of an install - and I got 2 more of the same style of opener on my new house/shop.
As for this years Power Tour - I'm passing on it since it is such a far drive in both directions for me. You being in Texas - at least its somewhat close for you.
Old 04-24-2016, 01:21 PM
I got the LS9 valve covers installed - as well as my Elite Engineering Catch Can.
I ended up having to order the oil fill tube for an LSA engine as the LS2 one will not clip in because the LS9 valve covers have an extra tab inside the cover - and they moved the tabs as well.
I am still waiting on some 90* fittings from Edelbrock - this will allow the PCV hoses to snap into the LS9 valve covers - as they are designed to clip in to them.
I am also waiting for a straight barb on the catch can - it currently has a 90* fitting on there making the PCV hose wrap around the can.
Once those come in - I will trim the hoses to the proper length and clean everything up.
Now for teh pics:
Old 04-28-2016, 05:01 PM
I finally got the PCV system finished up.
My 90* elbows came in from Edelbrock - I had to order them through Summit Racing and it ended up being a custom order.
These 90's snap right into the LS9 valve covers - and cleans up the PCV hose routing a lot.
Also - after adding the catch can I went on a 30 mile drive. I got home and filled up the can.
I added a PCV valve between the drivers rear port and the can. I went on the same drive - and there was barely anything inside the catch can.
So I think I got the oiling issue resolved.
As for the half mile event this weekend - I've done a bunch of work on the truck to get it ready to tow the Vette up to VA.
I added a trailer brake, discovered that the rear U joint was cracked - so had that replaced and the DS rebalanced, replaced the the transfer case fluid, and got an alignment and ended up having to replace one of the batteries. So after all this work - i should be good to go.
Old 05-02-2016, 10:14 AM
So the Wannagofast event didn't happen on Saturday.
I ended up having issues with my trailer that I had rented. I got home with the trailer and noticed one of the ramps was missing. I fought for a couple hours with all of my boards and race ramps at the house - and couldn't make up for that missing ramp. I couldn't get the Vette onto the trailer without screwing up the front bumper. I took the trailer back and got my money back - so I had thrown in the towel for the event on Saturday.
I slept in and started seeing all the Fog emails/FB pics up in the VA mountains.
They ended up not running at all that day - here is a pic that a friend of mine took.
I am glad I had the trailer issues - it saved me a 10 hour drive and I didn't have to get up at 4am.
I'm not sure whats next for the Vette - but I need to put some miles on this setup. I'll probably do a few local SCCA Autocrosses this summer - thats probably about it.
