Old 08-21-2015, 08:41 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Originally Posted by Build-It-Break-it View Post
Have you tried sourcing another vendor for the axles to bring the cost down from $450 per axle?
Talked with Dutchman and they were no less but can also produce and I have no doubt in their ability. Never spoke with Moser, but prefer Strange over all and do a great job. I like the quality of their products. Unless quantities per order increase, no substantial discount will apply as it is what it is for material, process, machining.
I know it is not an inexpensive set-up as you have pointed out before in earlier post, but this most likely will not be a deal breaker for those that really want it. Folks may have to save a little while longer but then will have an OEM type setup that is hard to compare in many ways to anything on the market.
Who knows, maybe someday I will be running hundreds of sets at a time and price will be cut in half! I can only hope
Old 01-24-2016, 04:40 AM
71RS/SS396's Avatar
Why not use the Seals-it inner seal and keep the oil in the center where it's needed? You need to relocate the axle vent but there's no need for the oil to be in the axle tube. http://www.sealsit.com/axle-seals.html
Old 01-24-2016, 06:50 AM
Default Seals-it
Hi Tim,
I include the outer seal in the kit since this will suffice most consumers usage, but I have no issues at all with this option if requested.
I have spoken with the folks at Seals-it for input as to optimal shaft size (at seal location) for best overall longevity of the seal, so if requested I can accommodate folks that may want to go that route.
Also while talking with Seals-it, it was mentioned that not all housing tubes are a "out of the box fit" for their product and sometimes require different O-rings and or machining of the O-ring grooves to obtain their suggested fitment, and is another reason for my including the outer seals that are certain to fit everyone's application.
Your input is greatly appreciated and further exposes another great option that folks can explore.
Thanks, Jay
Old 01-24-2016, 10:26 AM
Hugger67RSSS's Avatar
Hugger67RSSS Hugger67RSSS is offline
Jay, sent you a PM.
Aarik
68 Camaro 6.0/T56, Jake's Rod Shop C6 Subframe, JRS Torque Arm, Ridetech TQ Coilovers
Old 03-02-2016, 08:06 PM
Placed my order for one of Jay's bolt on rear conversions. Will post an install thread once I get my axles. Great guy to deal with and has a great product!
Aarik
Old 03-06-2016, 04:09 PM
Default Update
Updated my original post with some new info, pics, pricing, etc. Check it out.
https://lateral-g.net/forums/showthread.php4?t=49657
Thanks,
Jay
Old 05-23-2016, 04:17 PM
Just a quick picture of Hugger67RSSS at the Midwest Musclecar Challenge Friday (road course) & Saturday (auto-x). He is a regular competitor and is running one of the MillerBuilt "Bolt-On" Hybrid Floater Kits. He has been throwing everything at it but the kitchen sink and just keeps on ticking
Old 05-26-2016, 07:59 PM
Sonar Chief's Avatar
Cool
Oustanding ... great looking car, I'm gonna be ordering this same setup real soon. I'll send you a PM next week!
Michael
Old 06-01-2016, 07:04 PM
Michael
Michael,
Sounds good. Appreciate the support!
Jay
Old 07-04-2016, 05:53 PM
In stock!
