Old 06-07-2016, 08:26 AM
rushca01 rushca01 is offline
Default 68 Camaro clutch master cylinder options
Trying to put together a part list to install a tremec 6 speed in 68 factory auto camaro.
I want to go with a hyrdaulic setup and I'm trying to decide on what master cylinder to use with the speedtech ATS bracket. I'm ok with either a factory GM master cylinder but I don't know which one to use. I would also like the pedal to have a full range of motion without bottoming out, is this setup possible?
Aftermarket cylinders are ok too but trying to stay budget friendly.
Thanks for the help!
Old 06-07-2016, 09:39 AM
Musclerodz's Avatar
it uses the 4th gen master. You will need to drill a new hole in the pedal to get the travel and feel you want.
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-07-2016, 09:48 AM
I should add I want to use a hydraulic slave...I think that changes things.
Old 06-08-2016, 12:15 PM
Z06vette's Avatar
Z06vette Z06vette is online now
I have used the 98-02 Fbody slave & master with the speedtech bracket on a few swaps. That bracket should come with a new end for the master. Grind the crimps on the factory end, and remove it. Slide on the speedtech end, and weld it. Only other mod needed is the new hole on the pedal, as mentioned above.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 06-08-2016, 01:16 PM
Do you have to weld a stop on the floor?
Old 06-08-2016, 01:25 PM
Z06vette's Avatar
I did on my 69, but the others I didnt put a stop in. I thought it might be an issue, but so far it hasn't been. For as easy as it is to install, it cant hurt to add one.
69 RS LS3/T56
67 RS LS2/T56
Old 01-08-2017, 06:36 PM
MrElectric03 MrElectric03 is offline
I'm using a tilton on my setup. The 98-02 f bodies were notorious for horrible clutch hydraulics and lead to shifting issues. I used a Tick Master cylinder on my 01 WS6 to remedy the issue. Harder pedal feel and what some would say is too stiff but I got used to it. Instead of paying for the tick I found the tilton that they use and a conversion mount to use with the speedtech bracket and spent the same for all of it as a new gym master.
