Old 06-10-2016, 07:01 PM
64mali's Avatar
64mali 64mali is offline
Flattening them out on the end worked out well and most of what you see was covered by the cross member , including the butt weld
Old 06-13-2016, 12:21 PM
pro66tour's Avatar
pro66tour pro66tour is offline
With what you had in front of you, you have to be happy with the outcome. Looks like the rest of the build, CLEAN...
Old 06-15-2016, 12:54 AM
64mali's Avatar
Thank you pro66tour
Old 06-15-2016, 12:57 AM
64mali's Avatar
Finishing up the trunk floor. I spent a lot of time trying to make these aftermarket pans fit and hiding all the seems so you can't tell I ever put pans in it. It's taken a while but I'm happy with the progress so far.
This is the only visible seem and it cleaned up really well. Can't tell!
Little grinding and some putty
Old 06-15-2016, 01:00 AM
64mali's Avatar
And some primer
Old 06-15-2016, 01:01 AM
64mali's Avatar
Old 06-15-2016, 01:02 AM
64mali's Avatar
64mali's Avatar
Old 06-25-2016, 08:53 PM
64mali's Avatar
I'm really pumped I got the underside topcoated today! Now I can finally start putting this thing together.
Old 06-25-2016, 08:54 PM
64mali's Avatar
