Old 10-18-2006, 09:00 PM
Mizfit's Avatar
Mizfit Mizfit is offline
Default LS1: 414 Iron block L92 Heads/ Sheet Metal
414 iron block
Iron 6.0 Block
custom pistions - Diamond 4.060 Bore L92
cometics
Callies Compstar rods
arp main studs
arp rod bolts
eagle crank 4 inch
comp 850-16 lifters
L92 heads complete with exhaust porting
Patriot dual springs
Cam 246/253 .620 lift 112 Lsa
ported Ls6 pump
rollmaster dual roller timing chain
11:5:1 compression
Sheet Metal Intake specific to L92 heads with Fuel Rails
$7550 + shipping
Taylor
913-558-1100
Old 10-18-2006, 11:31 PM
mazspeed's Avatar
mazspeed mazspeed is offline
pictures?
Old 10-19-2006, 05:28 AM
Mizfit's Avatar
Covers and pulley not included unless you want to add them to the price.
Add $275 for covers and pulley
Old 10-19-2006, 06:26 AM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Any Dyno numbers?
Old 10-19-2006, 07:58 AM
Mizfit's Avatar
No but motor should put down between 520-550 at the wheels depending on drivetrain.
Old 10-24-2006, 05:33 PM
Mizfit's Avatar
Will accept reasonable offers.. Only until Friday then it goes to ebay..
Old 10-24-2006, 09:36 PM
4mm 4mm is offline
Very nice.
Old 10-25-2006, 03:29 PM
D Rock D Rock is offline
Nice, I plan on building a L92 motor one day. The head numbers are amazing for the price.
Old 10-25-2006, 06:07 PM
Mizfit's Avatar
The flow numbers are pretty amazing for a Stock GM casting. They are right at 330cfm intake side out of the box.
Old 10-28-2006, 06:46 AM
Mizfit's Avatar
I will throw in covers and ASP Pulley......need this thing gone
