Old 10-14-2006, 11:17 AM
Mike Hall's Avatar
Mike Hall Mike Hall is offline
Well I cant find anyone with 16 gauge steel thats open today. HomeDepot has it but its like $25 for a 1x2ft section which im not going to pay.
I guess I will work on getting the inner tubs totaly removed so I will be ready for my mini tubs.
Mike
Old 10-14-2006, 05:50 PM
comp-spec's Avatar
comp-spec comp-spec is offline
Originally Posted by Mike Hall
Do you have a cable setup or something for the wipers? I was thinking about going to the junk yard ad looking around until I found something that looked like it would fit inside the cowl. Any chance you have pictures of how you did your wipers?
Mike
we used a stock wiper motor and modified the arms in the cowl
http://www.competition-specialties.com/camaro1.htm
Old 10-14-2006, 10:14 PM
awr68's Avatar
awr68 awr68 is offline
I remember reading somewhere that a guy used a VW wiper motor because it fit in the cowl area...perhaps a quick google would find it?
Tony
'68 Camaro
Old 10-16-2006, 07:15 AM
Overkill's Avatar
Overkill Overkill is offline
Default My VW Wiper install
I used a VW wiper motor in my '69 Camaro based off of paul67's (over at pro-touring.com) original design. I have some pictures of my install over on my website if you are interested. http://www.camaroheaven.org/modules....howpage&cid=36
Here's on of the installed pictures:
You can ignore all the pictures of the Camaro wiper switch modifications, I ended up not going that route, but I left the pictures up just in case someone was interested in seeing what the inside of the switch looked like.
Michael
CamaroHeaven.org
Old 10-16-2006, 08:42 AM
Steve1968LS2's Avatar
That's what I just did. Well I made a pattern. I need to find some steel sheet big enough to cut this thing out. Im not sure If I will leave the wiper hole or not as I would like to come up with something that can mount in the cowl to operate the wipers.
Mike
That's what we did.. covered the whole darn thing
Old 10-16-2006, 11:18 AM
Mike Hall's Avatar
Thanks for the info Overkill. That will be very helpful when I get to the wipers.
Mike
Old 10-20-2006, 08:49 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Try mikes custom cars, I got my panels from him, fit great complete side to side all the way to the top.
http://www.mikescustomcars.com/index.html
