Old 08-18-2016, 10:27 PM
DannyZ's Avatar
DannyZ DannyZ is offline
Yes you can use a VFD to run a three phase motor with single phase power. You must buy the correct VFD drive for the proper current input and load, and voltage. Unless you have a VFD already that will work, you are fine, but if you have to buy a VFD , you should do the math and see if it is cheaper to buy a used motor instead. Remember, compressors are what is called a hard start, they are under a lot of load during startup. Dan
