Old 09-13-2016, 03:18 PM
Thanks, and feeling a little better today. Enough that I got in the garage a bit this afternoon to try to sort some issues.
Fuel pressure seems to steadily decline, but Carl has been excellent and we're working together trouble shooting it.
Had an issue just now with the push button start. Tried to engage the starter when I was trying to shut it down!!! Not good, and was a pain to get it to finally shut down. Wasn't too thrilled with that...
Called them and they said it sounds like it needs to learn tach again, I have been messing with the idle RPM so it very well could be the issue. I'll give it a shot and see if re-programming it stops it (i sure hope it does).
William
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 09-13-2016, 04:34 PM
Freedom_road's Avatar
Freedom_road Freedom_road is offline
Ok I thought I was crazy at around $80K, what do you estimate this completed build will cost?
Old 09-13-2016, 06:14 PM
Significantly more than that...
This is a project where things snowballed in a big way. I haven't put numbers to paper lately for a total and not sure I want to. Last time I did, i was probably double that already...
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 09-13-2016, 07:24 PM
DOOM's Avatar
DOOM DOOM is offline
Don't do it!!!
Mario
USCOLLISION
Old 09-14-2016, 04:38 AM
No joke. I got a friend to do it after he commented on only having a certain amount in the car he figured. It sounded very low so I said "add it up." Ended up being 30-40% more than he had anticipated.
I think the best advice I can share that I've learned is if you have 60k to build a car, plan to spend 30-40k and you MIGHT finish it before running out of cash.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 10-02-2016, 04:35 PM
Texas A&M BSME 2008
1992 Corvette ZR-1
The Following User Says Thank You to will69camaro For This Useful Post:
Roscoe03 (06-24-2021)
Old 10-02-2016, 05:46 PM
Zoomin Zoomin is offline
Looks great on the drive!
I predict a ride height adjustment in your future tho. How much clearance do you have on the inside of the wheel?
1964 Lemans
1966 Skylark
1969 Camaro
Old 10-03-2016, 09:54 AM
DOOM's Avatar
I would say that's pretty much it . I never in a million years thought I would spend that much on a automobile .
Mario
USCOLLISION
Old 10-03-2016, 05:30 PM
Centerforce's Avatar
Centerforce Centerforce is offline
Those are some GOOD noises coming out!
