Old 09-11-2016, 12:46 PM
zj510's Avatar
zj510 zj510 is offline
Originally Posted by ScotI View Post
Care to elaborate on what the "little things" you're experiencing are?
One of them was the idle stayed up a little when coming to a stop but i got that figured out by adjusting the iac. The other one i am experiencing is when going full throttle fast it seems to hesitate a little bit but if i ease into it, it has no issues.
1968 Camaro, 70 Camaro, 71 Datsun 510
Old 09-12-2016, 04:59 PM
ScotI ScotI is offline
Thanks for the info. I'm goig to help install one of these FITech kits on a buddys 71 ElCamino. It's semi radical (427sbc; 10.5:1; AFR 235's; agressive hyd roller profile/low vacuum & a Victor intake) so I'm concerned. I tried talking him into doing the Holley Terminator or something similar but the FITech guys are telling him it will work fine & he likes their price + easier appearing install.
Old 09-15-2016, 01:07 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Hi Zak....Once again, car is stunning!! On your front end set-up, what control arms, shocks, spindles did you use. I'm in the planning process on my 70 build...already have the 12 bolt and quadra-link set up. While my car will most likely see a little auto cross....it will be mostly a street car with a bunch of LS HP (LSA). For the driving you have done...how do you feel the front end components you chose are working out?? The stance on your car is killer!! I am leaning towards the DSE front sub, but that comes at a cost..... However, the numbers (cost) for control arms, shocks, spindles, steering box, sway bar seem to approach the cost for an aftermarket.....
Thanks, Dave
Old 09-15-2016, 03:50 PM
zj510's Avatar
Thanks, Dave
I have the global west upper and lower control arms and did the custom works performance coil over conversion that is a bracket welded in the pocket not just the coil spring coil over. I went with the cpp c5 spindle so the z06 brakes bolted right up. So far all i have done is just drive it around town and threw it through some corners and it handles and feels real good but its hard for me to say since i haven't driven a car with one of the aftermarket sub frames. The only reason I went with the global west control arms was a buddy went to wide of wheel and had to get some arms that were narrower so i got them at a really good price but they are a really nice piece.
Old 09-15-2016, 04:40 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
The color looks beautiful on this car. I love it...you did well!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 09-16-2016, 07:42 AM
67XR7's Avatar
67XR7 67XR7 is offline
Love the car!
Been following you on IG. Glad to see more and more local G-machines.
1965 Chevelle, Pm me if interested in wheel tool rental
Old 09-16-2016, 08:37 AM
Radlark's Avatar
Radlark Radlark is offline
Maybe I missed it but what color is that? That car is very well executed!
Old 09-27-2016, 08:36 PM
DKz Garage's Avatar
Thanks for the info...the parts came together nicely!
Old 02-10-2017, 01:14 PM
WOW. The engine looks awesome! Excellent choice for the color. Def. different. Is the Z06 front calipers 6 piston? What about the rears? The CPP C5 spindles look promising. WHat master cylinder did you have to use for the Zo6 brakes?
again...... WOW. LOL Thanks for sharing
Old 02-10-2017, 06:56 PM
SS Performance SS Performance is offline
Nice build.
Who's pulley/accessory drive setup is the?
Craig
man's garage is his castle
1970 Camaro SS
2002 Camaro B2C
2015 Camaro 1SS 1LE
