Old 10-18-2016, 08:34 PM
syborg tt's Avatar
Very nice
Marty-MJ
marty-mj
Old 10-19-2016, 10:00 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Thanks guys.
Old 10-19-2016, 12:46 PM
Beautiful job AJ.
Old 10-19-2016, 05:24 PM
Centerforce's Avatar
Centerforce Centerforce is offline
We're loving the creativity and out-of-the-box thinking here. Its easy to throw together a build using parts that are readily available, but true dedication to make something completely custom and unique!
Old 10-19-2016, 06:39 PM
CamaroAJ's Avatar
Thanks guys, lots of cutting coming soon. I did some rough measurements and I think what I'm planning just might work out like I hoped it would.
Old 10-20-2016, 10:59 AM
FlameBroiled's Avatar
FlameBroiled FlameBroiled is offline
We need a like Button
www.Eyekandykustoms.com
Old 10-23-2016, 10:34 AM
CamaroAJ's Avatar
Work was slow yesterday so I had some time to finish the passenger door handle. It too needs some hammer and dolly work, but it's mostly there.
h
Then I got the oil tank area cleaned up and ready to fit the tank in once I order it.
Then I finished removing the EDP coating from the door
That's all for now. Hopefully going to pick up some new to me suspension today so I can start getting that handled.
Old 10-30-2016, 10:09 AM
CamaroAJ's Avatar
Long story short, when I started this project originally I had something specific in mind. Basically I let people talk me out of what I wanted and into some choices I didn't really want when it came to my car. So after debating a lot about things with cost and how much of a set back it is, I decided that I can always make more money and I'd rather be happy in the end instead of regretfull.
So, here we go, starting all over with the suspension.
A friend of mine wanted my speedtech front clip and as luck would have it, he had the full front and rear suspension, transaxle, torque tube, and a bunch of other parts from a '04 C5 Z06. We made a deal in which we both came out ahead and I got a little extra cash to help offset materials cost for the mods.
Now for the measurements, they are really close. As in borderline it might be possible to not cut suspension or outer body panels with a custom offset wheel. I'll be calling forgeline Monday to see how close I can get. This is where the stock offset wheels sit. They need to move in about 1.5"
This is just a rough setup to get some measurements off of while I wait for the stock vette rear frame to show up. Based off a XLR we had at work I got some measurements off of, the outside to outside frame rail is 10" to wide to use in my car. However the inside to inside measurement does indeed fit inside the stock '69 outer rockers so I'd be able to run 2x3 or possibly 2x4 square tube in the rocker and use stock C5 fuel tanks as well. More to come on that as I get the car braced up, a frame jig built, and more cut out of the car.
Old 10-30-2016, 11:51 AM
Beechy's Avatar
Beechy Beechy is offline
Default Change of direction
Nice work on the new concept.........subscribed....
Jim Grant
Melbourne, Australia
(Dual citizen)
Old 10-30-2016, 01:23 PM
frankv11's Avatar
frankv11 frankv11 is offline
Can't wait to see the updates
