Old 10-26-2016, 06:15 AM
1Bad68Cat 1Bad68Cat is offline
Originally Posted by 69greyghost View Post
Hey guys, I wanna run a gen 4 brake booster on my 69. My buddy told me to buy this dse bracket and thats all I need, is this correct? The info on the bracket says it only works with a special dse booster. Thanks guys let me know what you think.
I installed one on with friend's 69 camaro a few years back and on another after. I can't recall if all 4 bolts on the existing bracket match the firewall or if only 3 do. I can check when I get home. The one hole I know for sure that didn't match was the large diameter hole the push rod goes through. I welded the hole shut and redrilled it higher. I then mounted the pushrod onto the lower hole in the brake pedal.
