Old 05-06-2016, 02:30 PM
V8TV's Avatar
V8TV V8TV is offline
Aluminum parts like the supercharger and transmission were cleaned and masked, then they were sprayed with Eastwood nano ceramic high temperature engine paint. They were sprayed in satin silver to keep an aluminum look, but now they will stay this way without corroding the way cast aluminum does.
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 12-03-2016, 02:37 PM
V8TV's Avatar
With most of the pieces painted, it was time to start putting the truck back together. The crew began by reinstalling the wiring harnesses, ECMs, relay centers, Vintage Air equipment and ductwork in the dash.
Next, the inner fenders were reinstalled and the crew installed as much wiring as they could before the engine and transmission were dropped in place.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 12-03-2016, 02:38 PM
V8TV's Avatar
The supercharged 5.4 liter V8 was reassembled with it's freshly detailed parts, including new gaskets and wrinkle coated valve covers, new gaskets for the supercharger assembly, and other detailed pieces. The supercharger has been upgraded with a higher RPM pulley for increased compression. The goal was to install as many connectors, harnesses, hoses and hard lines as possible while the engine was on the stand to make installation go quicker.
The radiator core support was built on a stand before it was installed in the truck as an assembly. The core support assembly consists of the support, radiator, electric cooling fans, fan controller, steering reservoir, AC condenser core, oil cooler, and coolant reservoirs. The supercharger heat exchanger would be attached after the core support was installed.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
V8TV's Avatar
The transmission was bolted to the engine and the whole assembly was lowered into the truck including all the wiring and the headers.
The core support assembly was installed, and then the heat exchanger was added. The new brake lines were put back in place, as well as the master cylinder and Hydratech hydraulic brake booster unit. The factory 2002 Lightning anti-lock brake module and hardware was installed, which remained functional in the 1969 truck.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 12-04-2016, 10:17 AM
gofastwclass gofastwclass is offline
Nice update, the truck is looking great!
Is it bad that each time I read one of your posts I hear you narrating it like on your You Tube channel?
I build my own junk...
Old 12-04-2016, 01:49 PM
V8TV's Avatar
Ha, too funny. I'm not sure I ever wanted to be the voice in someone's head... but I promise not to steer you wrong!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 12-04-2016, 02:22 PM
LOL. Glad I'd not the only one. I'm betting this is because I've watched his videos and know his voice. LOL
GREAT JOB!!!
Old 12-04-2016, 07:25 PM
V8TV's Avatar
GREAT JOB!!!
Thanks Jimbo! The team did some nice work on this one.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 12-04-2016, 07:26 PM
V8TV's Avatar
Underneath the truck cab, the 4R100 electronic overdrive sits comfortably on it’s new mount.
Topside, the pieces are coming back together, like the power steering and hydroboost lines and the fabricated cover for the radiator and coolers.
Wiring is hidden below the inner fender, which will all be tidied up and protected with a the new splash shields. AC and heater lines route through as well.
The driver side hides the forward harness lines in a similar fashion.
Here, the painted air intake is reinstalled, along with the throttle and cruise control cables.
Hoses are kept tight with Gates heat shrink clamps.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
V8TV's Avatar
The inner fenders and grille assembly are reinstalled.
Inside, the Dakota Digital VHX gauge system is reinstalled in a restored dash bezel. Heat and sound deadener is installed.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
