Old 12-19-2016, 07:03 AM
Tim john--- Tim john--- is offline
Default Vintage Air 5/8" heater hose to LS water pump ? HELP.
I am installing Vintage Air and the heater hoses are both 5/8" coming off the V/A unit, my engine is a 2004 GTO LS-1 and the water pump tube connections are 5/8" & 3/4". What is everyone doing to mate the hoses up ? I can machine a tubular transition piece but thought most everyone here has gone down this path already. My preference is a 45° pre molded connection at the water pump for both hoses to route the lines neat and orderly. Options of pulling the water pump, remove the tubes and tap for fittings, use a pre molded 45° elbow and machine up a tubular transition piece, etc.. Please let me know what and how you accomplished the same. Thank You very much.
Tim john---
Old 12-19-2016, 08:08 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Dayco 87616 Hose
5/8 Hose belled on one end to 3/4"
I cut the 6" 3/4" part down to about 1 1/2"
Old 12-19-2016, 08:25 AM
Thank you very much for chiming in, I will still need to come up with a 45° elbow at the water pump fitting. This hose will certainly help.
Tim john---
Old 12-19-2016, 08:33 AM
Vega$69's Avatar
Tim john---
I've never had to use a 45* on the WP. The hose is flexible enough to clear
Old 12-19-2016, 08:46 AM
cpd004's Avatar
cpd004 cpd004 is online now
I used the hoses pictured here. Not the plastic elbows. I'll try and dig up both part numbers.
1971 Firebird
2017 SS
Old 12-19-2016, 09:29 AM
Andrew_at_Painless's Avatar
Andrew_at_Painless Andrew_at_Painless is offline
I went a little bit overkill.
I heated the factory pressed in barbs, grabbed them with vice grips, and knocked them out. I then went ahead and tapped it with 1/2" NPT and 3/8" NPT and bought AN fittings that I'll adapt down. The 1/2" NPT to -10 AN is just a standard 90 degree, then the 3/8" NPT to -10 AN is a swivel as I wouldn't have been able to tighten both without them hitting one another.
I then used Russel Pro Classic since I loved the look and it matched everything else under the hood. I then adapted using 10AN to hose barb fittings behind the fender to just standard rubber 5/8" heater hose where you can't see it. Unfortunately those pics are on my laptop since they're from my old phone.
1998 Volvo V70 - I can't get away from them.
2007 GMC Sierra Crew Cab Classic
2018 Kawasaki Z900RS - Root Beer & Orange Retro Goodness
1971 Camaro Z28 RS - "Barn Find" -LS/4L80/Strange 9" Restomod Beater
