Old 02-03-2017, 02:39 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Originally Posted by LS3 HQ View Post
Couple more pics. Firewall is 100% finished now. Speaksy also made up some nice fender mounts as the old ones wouldn't work with the body drop. I think these are a bit better!!
Your build is top notch man.
Since the steering is going to be on the right side, make sure you swap the speedtech motor stands. The taller one should be installed on the driver side and the shorter stand to be on the passenger side. By swaping the stands, the engine will move by 3/4" to the passenger side to clear the rack and pinion.
72 Camaro RS:SOLD
68 Camaro:
Old 02-06-2017, 03:08 AM
LS3 HQ's Avatar
LS3 HQ LS3 HQ is offline
Originally Posted by Brewtal66 View Post
This car is wicked!!! Love how you've made is so low.
Thanks Tim. It's certainly not what I pictured a few years ago.
Cheers man. Yep came across this problem a few weeks ago. We were going to make some new mounts to centre engine but may not be able to. Mounting steering this week so will know in the next week or so.
