Old 01-13-2017, 06:03 AM
l2azorback l2azorback is offline
Default DSE Super Tank 1000 - 1969 Camaro
Item Location (City/State): Red Bud, IL
Price:$old Shipped CONUS
Payment Options: PayPal +4%, or Direct Bill from V8SR, Kelle can send an invoice to you so you can use your Credit/Debit/Checking Account.
Description: Hello, I have a gently used ~350 miles DSE Super Tank 1000 Stainless Steel fuel tank that has been narrowed for the 1969 Camaro, works with DSE mini tubs, and has notched corners for exhaust clearance. This set-up is designed to support up to 960hp NA. I changed directions with my build, and am no longer in need of this set-up.
DSE Website info:
1000 Series Standard:
• Dual 190Ltr/Hr Pumps
• Same Basic dimensions as 5th Gen module
• VaporWorx Pulse Width Modulation (PWM) Kit Required
• 19 Amp Draw
• 80.3 GPH @ 60psi
• 960HP Normally Aspirated
• 800HP Supercharged
Tank does NOT come with a fuel pump or PWM controller, as I am using them in my new set-up, thus the price adjustment, as these are over $2700.00 new, plus shipping. This tank still has the pick-ups in the corners and associated internal plumbing to include the sending unit that came with the tank. A new CTSV fuel pump is $495.00, and the Vaporworx PWM fuel pump controller is $525.00. You can have this awesome returnless set-up for much less than what I paid new. I was feeding a Scott Shafiroff 540 Ultra Street BBC with Holley HP MPI with absolutely no issues.
Regards,
Larry
Old 01-21-2017, 06:35 AM
Bump....
Old 01-23-2017, 09:44 AM
Bonebuster29 Bonebuster29 is offline
if only it was for a 67/68...
68 Firebird - Build still in progress
DSE Speed kit 3, Glink rear, Moser 12bolt, LS3 540hp, T-56 Mag, Willwood Areo brakes...
Old 01-24-2017, 03:46 PM
Zl1427 Zl1427 is offline
Will this work with DSE Mini tubs?
Old 01-26-2017, 07:01 PM
Yes,
This tank works with DSE Mini Tubs. My car has DSE mini tubs.
Regards,
Larry
Old 02-01-2017, 10:45 AM
Price drop $1000.00 Shipped
Old 02-02-2017, 10:39 AM
aany001's Avatar
aany001 aany001 is offline
Sent a PM
Old 02-18-2017, 08:35 AM
Bump...price drop....$950.00 shipped
Old 02-24-2017, 03:24 PM
aany001's Avatar
Larry I sent you a PM.
Steve
Old 03-25-2017, 08:24 AM
Bump...last price drop
