03-04-2017, 01:58 PM
Steering options for S.Mock Subframe.
I'm finally getting around to assembling my sub frame, I know I need to use a 3/4x16 u joint, but I'm trying to figure out what the best route on this,
I see CPP make a Collapsible steering shaft that goes from the stock column to the rack,
http://www.ebay.com/itm/CPP-Collapsi...item41bba09f4d
Then there's Speedtechs version, which you get the adapter from factory column to the u joint to the rack,
http://www.speedtechperformance.com/...rod/prd417.htm
just picking some brains while I'm home assembling this,
03-09-2017, 08:40 PM
Talked to Scott, I'll check with Jegs, also, working on other parts as well,
03-10-2017, 07:34 AM
Anyone have any certain experience with stainless u joints, good, bad, indifferent?
I know I'm not the only one on this site that's used a aftermarket sub,
05-21-2017, 08:35 AM
Which did you pick? I just went with steel because I intended to paint it all black, if stainless I would have wanted to polish it all up...
05-24-2017, 03:46 PM
nothing yet,
