Old 03-09-2017, 08:31 AM
Panteracer's Avatar
Default 69 Camero
I used to run one up front years ago with just rubber hoses
and clamps with no issues... Then when I put my new engine
in I mounted one in the same location with An fittings but -14 lines
so I could get the flow... problem was sometimes when the engine
flexed in torque it would loosen the fittings.. again it had very large
lines but make sure the torque of the motor will not twist on the fittings
Nice build.. love all the little details
Bob
Old 03-09-2017, 08:53 AM
Sandro's 1969 502 Camaro's Avatar
Sandro's 1969 502 Camaro Sandro's 1969 502 Camaro is offline
Bob
Good to know! Thanks Bob.
Old 03-09-2017, 11:56 AM
Might consider safety wire then or securing the hose to the frame before it gets to the filter head. That way, the hose takes the flex and not the fitting at the filter head.
Good location for the filter IMO
Old 03-09-2017, 04:05 PM
Thanks Trey.
I think I'm going to commit to that location and cut my inner fender. When I start plumbing the system I'll see what options there is for the hoses.
Btw looks like you've done a ton of work on your car too, its awesome. I cant wait to be driving mine! These cars are hard to build on a budget so mine might be a while longer. This site has ruined me lol.
Old 03-09-2017, 04:14 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Very impressive work so far,keep the pics coming
Old 03-13-2017, 12:10 PM
Put a few hours in the garage this weekend and finished mocking up the remote oil filter. I made a close out panel so it wasn't visible from the front wheel well. Once I get the front end alignment finished I'll install some mounting hardware for the closest panel.
The Following User Says Thank You to Sandro's 1969 502 Camaro For This Useful Post:
syborg tt (11-13-2018)
  #37
Old 03-13-2017, 01:20 PM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Very nice! ^^
Old 03-15-2017, 03:31 PM
Sandros,
Do you what airfilter PN?
Thanks,
Jim
Old 03-15-2017, 05:59 PM
Originally Posted by Jimbo1367 View Post
Sandros,
Thanks,
Jim
Yes, it's a K&N RC-3160
Old 03-16-2017, 08:08 AM
ScotI ScotI is offline
Well done mod right there.
