Old 04-26-2017, 07:14 AM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Default NEW Chassis options from Roadster Shop
Thought it would be a great time to let some of you guys know about some of the newest applications available in the SPEC series of chassis, there should be something for just about everybody. Not going to do a huge sales pitch here just some highlights , pricing and of course.....pictures
The new SPEC series of chassis from Roadster Shop feature
* SPEC IFS with front mounted Power rack and pinion
* easy to align eccentric mounts on upper a-arms with Pro Forged spindles
* single adjustable coilovers
* 4 bar rear suspension with 9" rear housing and 31 spline axles
* motor mounts for SBC, BBC, or optional LS motor mounts
* will fit 12" wide rear wheel (with mini tub)
* CAD engineered frame design with RS exclusive laser cut and contoured
frame rails that allow the chassis to sit tight to the body and requires no
floor modifications
* True 100% bolt on design utilizes original body, bumper and, core support
mounts
Roadster Shop SPEC series for 1967-69 CAMARO
PRICE AS SHOWN $9895.00
for more info you can check out a lot more details, pictures and videos in the Roadster Shop Chassis and suspension vendor section here https://lateral-g.net/forums/showthread.php4?t=54852
www.roadstershop.com
Old 04-26-2017, 07:59 AM
fleetus macmullitz's Avatar
Very nice.
Old 04-26-2017, 09:39 AM
andrewb70's Avatar
Is this for 1st gen F-body only or other platforms as well?
Andrew
Old 04-26-2017, 01:50 PM
Z06vette's Avatar
Z06vette Z06vette is offline
What size front tire can be used on a 69 camaro? Could a ridetech shock be used? Does the trans tunnel require raising when running a 6 speed manual?
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 04-27-2017, 06:45 AM
Supporting Vendor
RoadsterShop.com
Scott,
On the front tire sizes , while we have not yet done a 69 in house , I do know of a few customers of ours that have done both a 265 and a 275, and both worked well , without any modifications other than making sure you get the correct backspacing on your wheels.
However , I would suggest you go to the Roadster Shop chassis Vendor section here https://lateral-g.net/forums/showthread.php4?t=54852
and check out the great chart showing actual real world results of a 245 front tire versus 315s, I think you might find it useful.
No floor mods are necessary for the T56 , you will have to re locate the shifter hole obviously.
While Ride Tech makes a great shock, the shock body, lower mount, and upper spring retainer will not allow it to fit on the front of the SPEC IFS. The base shock is a Strange Single Adjustable and you have the option to upgrade to an Afco Double Adjustable or take it to the top level and do a Penske Double Adjustable or Triple Adjustable remote reservoir shock.
Thanks , and hope this helps answers some of your questions
Old 04-27-2017, 07:51 AM
paulk68 paulk68 is offline
Will Baer brakes made for stock 67-69 camaro spindles work on the SPEC
Old 04-27-2017, 12:50 PM
Supporting Vendor
RoadsterShop.com
Paul , the SPEC chassis utilizes the Wilwood pro forged spindle and Baer has several kits available for that spindle, however a kit for a stock 69 camaro spindle would not work
Old 04-27-2017, 07:37 PM
Dave95z28 Dave95z28 is offline
Did you weight the car prior to installing the Spec frame? What weight increase can be expected?
Old 05-02-2017, 07:13 AM
Supporting Vendor
RoadsterShop.com
Dave, the completed 68 test vehicle weighed just shy of 3400 with iron block and dynamat, stereo , etc. so very comparable to other muscle cars like this
Old 05-02-2017, 09:27 AM
Supporting Vendor
RoadsterShop.com
Here are some more offerings in the Roadster Shop SPEC series ,for those of you that are building something other than a Camaro.
NEW C10 chassis bagged SPEC series from Roadster Shop
1960-1966 C10 ...and... 1967-1972 C10 ..and.. 1973-1987 C10
$9895.00
NEW Chevelle full chassis in SPEC series from Roadster Shop
1964-1967 Chevelle .. and.. 1968-1972 Chevelle Roadster Shop SPEC chassis
$9995.00
NEW F100 complete chassis SPEC series from Roadster Shop
1967-1972 Ford F100 Roadster Shop SPEC chassis
$9895.00
NEW Tri Five Chevy chassis SPEC series from Roadster Shop
1955-1957 Chevy Roadster Shop SPEC Tri Five chassis
$9995.00
NEW Impala complete chassis from Roadster Shop
1961 -1964 Impala Roadster Shop SPEC chassis
$9995.00
