Old 07-30-2016, 06:21 PM
KHShapiro KHShapiro is offline
Tom is a good dude, I think those fenders have been redone 3 times to get them perfectly the way I wanted them lot of Blood Sweat and Tears in that car
Old 05-17-2017, 12:27 AM
We could not get the stance I wanted which matched the rendering AND have a functioning suspension. This means I had to make a decision to channel the body and cut out the Speed Tech pro-touring subframe which had never seen the road. I figured well if I'm going to do that I might as well just get the Speed Tech ExtReme subframe, so I did.
Next is line is the firewall and trans tunnel mods, then off to have the cage put in.
Old 05-17-2017, 12:48 AM
first channeled Speed Tech ExtReme gen 1 Camaro?
Old 05-18-2017, 09:28 AM
Sucks that the subframe had to be removed but at least you realized that now and made the changes while you could. Good luck!
Old 09-25-2019, 05:57 PM
body channeled over the subframe and frame connectors. tunnel had to be moved as well .
ride height will be controlled by JRI hydraulics
Old 09-26-2019, 01:54 PM
Man I'm glad to see you posting an update, I love this build.
Old 09-26-2019, 05:30 PM
Thank you!
