Old 06-23-2016, 04:50 AM
flatoutz flatoutz is offline
Jay,
Thanks again for the info.The photos are helpful.My only concern with your bolt on system is the load bearing on those four mounting bolts.
Mike,
Old 06-23-2016, 06:14 AM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Originally Posted by flatoutz View Post
Jay,
Mike,
Mike,
No need for concern as the C6/C7 Billet Flange actually indexes onto the remaining portion of the factory park brake dust shield register. By doing this the mounting hardware is simply used for clamping force (tension), and will not experience shear force. In addition, the 1/2" threaded bosses that protrude off the C6/C7 Billet Flange are the icing on the cake so to speak as they further enforce this.
Great questions and keep them coming !
Jay
Old 07-02-2016, 01:14 PM
Default In Stock!
These kits are in stock! See original post for details/pricing.
https://lateral-g.net/forums/showthread.php4?t=52854
Please do not hesitate to ask question!
Old 07-28-2016, 08:48 AM
98ssnova's Avatar
98ssnova 98ssnova is offline
So that install is awesome this is on my list!!!!
Old 08-06-2016, 10:56 AM
Default FREE Shipping & PayPal This Weekend!!
FREE Shipping & PayPal This Weekend!! (8/6/16 & 8/7/16 - "lower 48" states only)
Old 08-16-2016, 08:45 AM
csouth csouth is offline
Great product! WIsh this was around when I bought my Moser floater, would have savedme lots of time....
Big dreams, small pockets....
Chris--
'72 Cutlass S LS2/4L70E
Rushforth Wheels, SC&C, ATS, Street Rod Designs, Holley EFI
Project Motor City Madness
Old 08-25-2016, 08:41 PM
nyciti nyciti is online now
No provisions for ABS?
Old 08-26-2016, 01:24 AM
Pretty sure that the hub has the sensor mounts in them .....and let's be honest who beside steilow is actually running abs...people talk about doing it but never do
Old 08-26-2016, 07:25 AM
Yes, special order - the adaptor requires another "process" and to raustinss point, most folks are not interested or will never utilize the abs capabilities. By eliminating this machine process I save the majority of buyers money on something they do not require.
If you need this just let me know and we can get your special order rolling.
Thank you for your interest!
Old 10-01-2016, 02:48 PM
Default October Special!
FREE Shipping & PayPal through October!! ("lower 48" only)
C6/C7 Hybrid Floater System -
[SIZE="4"]Installs onto GM 10/12 Bolt (except Impala or Truck)[/SIZE] rear-ends,,,,, BOLT-ON!
That's right, you can use your current GM 10/12 Bolt rear-end housing, NO welding & simple installation!
Advantages:
  • Bolts to GM 10/12 Bolt housing end / brake flange (except Impala or Truck)(Big Ford application also available! https://lateral-g.net/forums/showthread.php4?t=49657 )
  • Eliminates the weak/dangerous factory c-clip axles
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Note: this applications will add 1/16″ per side to your existing wheel mount surface (based on an existing 2.810″ axle/brake offset)
Fitment: OEM 10/12 Bolt Rears: 67-81 Camaro, 64-72 Chevelle, 64-74 Nova
GM 10/12 Bolt Bolt-On “Base Kit” (pictured below)
GM 10/12 Bolt Bolt-On “Base Kit” (pictured above)
Base Kit Includes:
• (2) Billet Steel, C-Series, Hybrid Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) C7 Corvette, SKF 33 Spline Hub Assemblies
• (1) Install Kit
• (2) Hub Spacers
• (2) Billet Aluminum Hub Cap Seals
________________________________________
PRICED AT - $1498.00
Add Axles - $400.00
• (2) Hy-Tuf Full Float Axles
Add E-Brake items - $325.00
• (2) C5/C6 Corvette Complete E-brake Assemblies
• (2) C5/C6 Corvette Parking/E-brake Cable Brackets
Have interest?
Have questions?
Need more info?
Dealer Inquires Welcome!
Below pics of the assembled "Base Kit".... (attached 10/12 Bolt End is for display purposes only)
Below pics shown with optional C5/C6 E-brake Assembly & E-brake Cable Bracket. These two e-brake items are optional and the system can be run without and added at a later date if desired.... (attached 10/12 Bolt End is for display purposes only)
Few pics below of this 10/12 Bolt Kit in action!
