Old 07-15-2017, 12:20 PM
A lot of small progress done since my last post we installed a couple of fittings on the power steering reservoir and I plumbed it in and mounted on the fender well. I used XRP hose and AN fittings made for power steering pressure.
After talking to rep from Injector Dynamics who recommended a 10 micron filter, I picked up a Fuelabs ceramic filter good for all fuels. Then we marked up some hoses that will need to be sent out to be crimped. This pic only shows where it will be mounted, it still needs to be attached to the firewall. I.D. wanted it as close to the injectors as I could get it.
It's not as close as it seems to the header plus it has a heat protection cover on it. The bottom of the filter will be moved over to mount it plumb.
Old 07-15-2017, 01:32 PM
We're into the wiring now Not my favorite.... Like Greg W. says one thing at a time!
I had the injector harness covered the same as the rest of the wires but it was too stiff to go where I needed it, so it went back to the way the factory had it.
And my latest part from GM $28
GM tucking it to to you one part at a time!
Old 07-16-2017, 06:23 AM
kwhizz's Avatar
kwhizz kwhizz is offline
$15 thru gmpartsdirect.com Just Say'in ........
Old 07-16-2017, 07:06 AM
dhutton dhutton is offline
$11.99 with free shipping on eBay...
The annoying thing is there is likely less than fifty cents in cost for that connector.
Try to avoid buying parts at a dealer if you can Wayne. Sometimes it's hard to find a part number but there are dealers online with detailed parts diagrams with part numbers. You can save a lot of money and these build are costly enough as it is.
Old 07-16-2017, 07:27 AM
She's coming along nicely Wayne!
Old 07-16-2017, 03:20 PM
gofastwclass gofastwclass is offline
Good plan but GMPartsDirect's shipping prices are robbery, BTDT... ONCE. Same part number is 13.42 on Amazon Prime.
Nice progress.
I build my own junk...
Old 07-16-2017, 08:44 PM
gofastwclass I agree!
Ken I checked
GM Direct. from the Cart.
Subtotal Amount: $15.18
Estimated Shipping to Fall River, MA: $13.21
Plus wait 7-10 days. Only thing good about the dealer he had it the next day.
Don I didn't see that .... Figures. For that big of a saving I would have waited for it.
Thanks Greg. I'm trying.
I posted a question in the LSX conversions section tkae a look.
Old 07-17-2017, 06:09 PM
cryptonomad cryptonomad is offline
[QUOTE=waynieZ;662278]We're into the wiring now Not my favorite.... Like Greg W. says one thing at a time!
Looking good Wayne! A lot of quality work!
Old 07-17-2017, 08:39 PM
[QUOTE=cryptonomad;662417]
Thanks I'm trying. Welcome!
Old 07-18-2017, 02:15 PM
We took a brake from the Transmission and mounted the 5th gen console in the car for its test fit. It's going to work out pretty good with the B&M Pro Ratchet shifter. The cable might be a trick but we have a few ways to try.
