Old 08-03-2017, 08:30 PM
DOOM's Avatar
DOOM DOOM is offline
Unhappy Holley Dominator EFI hard starting after warm up
Well guys on to the next problem. My car is very hard to start after warm up. It will turn over for quite some time before it starts . Cold starts are okay . Any ideas Trying to set up my laptop so I can see what's going on but that's another story .
Mario
USCOLLISION
Old 08-04-2017, 07:08 AM
I'd be looking for areas where your fuel line is getting too warm. Even with fuel injection you can get heat soak. Also, look at your fuel pressure and make sure your tank is venting properly.
Old 08-04-2017, 07:45 AM
Vaporlocking in the rails? How is your fuel system routed. What fuel? I had zero starting issues with 93 and only a small delay when starting on E85.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 08-04-2017, 08:03 AM
carbuff's Avatar
carbuff carbuff is offline
Do you have a fuel pressure gauge?
Hard start can be a bit tricky. In the Holley, you have to get the air/fuel set somewhat manually with the IAC opening and startup fuel. The tables are based on CTS, and take some experimenting.
Also, the Holley has a fixed timing advance for starting. Where is that set?
Old 08-04-2017, 10:35 AM
DOOM's Avatar
Thanx for the info Todd I'm on it!
Will I'm running VP 100 I'm going to look at the routing this week.
I do have a gauge I just have to find out what the pressure should be. This Holley EFI is all new to me . Glade I have you guys!
Mario
USCOLLISION
Old 08-06-2017, 07:03 AM
carbuff's Avatar
Generally you will be at 43 or 58 psi, and there is a setting in the Holley setup which indicates what pressure you are using. If the car is running ok once started, that should all be fine. I was curious if you were getting pressure during hot start based on the vapor lock questions. I'd be surprised if that is the problem with a higher pressure style EFI pump, but I suppose it's possible...
Old 08-08-2017, 08:31 AM
highly doubtful.... you'd basically have to have heated up the entire tank of fuel.
Here IS a problem I've seen with EFI and the higher fuel pressures..... is when someone creates a VACUUM situation with a fitting (not pressure). Fuel boils with VACUUM... (it's not really boiling - it cavitates).
I'd be looking for a RESTRICTION in the fuel system.
Old 08-08-2017, 08:32 AM
I thought this car was pro built?
Old 08-08-2017, 08:48 AM
Is there a controller on your pump Mario -- because most fuel pumps are NOT continuous pumps.... but if they're not controlled then they turn into continuous pumps and as such get hot. Then you add heat soak - and then they start boiling the fuel... and don't pump worth a damn. That would show up on hot start.
Old 08-08-2017, 11:43 AM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
PM sent, Mario
www.roadstershop.com
