Old 08-27-2017, 08:52 PM
Musclerodz's Avatar
If you having to pick the pedal up, make sure you do not have an interference at the firewall. Also make sure you have the calipers shimmed within spec. If you have a pad riding on the rotor, it could build enough heat to push on the rotor if it doesn't have proper clearance.
Mike Redpath
Musclerodz & Customz
facebook page
