Old 09-14-2017, 05:35 AM
supremeefi supremeefi is offline
Originally Posted by DOOM View Post
Mark you have no idea! My car has been to three tuners . The last one got the car running awesome . That is when you can finally get it started. So you ask,'' Was it doing this when you had it?????????'' Of course it wasn't!!!!!! HOW THE F@CK CAN IT NOT ITS TRYING TO START AT 38 DEGRESS ADVANCE!!!!!!!!!!!!!!!!!!!!!!!!!! We go to the dyno tomorrow My nephews guy has the place rented for the afternoon. This will be the first time I'm going so I can see for myself that everything is good to go.
Best of luck, keep us posted.
Regarding the timing issue, I've always told others just because you CAN do that doesn't mean you SHOULD do that. Plus too many charge too much $$$. This ain't that difficult.
Again best of luck.
Mark
Engine builder and tuner.
Old 09-19-2017, 10:29 AM
DOOM's Avatar
DOOM DOOM is offline
Well we had a productive outing at the tuner last week . The car starts perfect now. It wasn't hard to figure out the starting problem it was trying to start at almost 50 degrees advance !!!!!!!!!!! We thought it was 38 degrees at first but we were wrong. Now with the MSD starter saver it works perfect. I'm going to run it this way until Holley makes the distributor I need . They currently don't make the short version I need for my car.
Mario
USCOLLISION
Old 09-19-2017, 10:35 AM
Good to hear Mario!!!
Just one other question on the brakes -- no need to respond here -- have you checked your PEDAL RATIO -- it should be 6:1 or so ---- not the 4:1 for power brakes.
My guess is -- that Master Cylinder is too small diameter and might not be able to provide the VOLUME required for your huge by large braking system.
Old 09-19-2017, 03:41 PM
DOOM's Avatar
That's exactly it Greg!
Mario
USCOLLISION
Old 09-21-2017, 04:22 PM
andrewb70's Avatar
So what you're telling me here is that the Holley Dominator never controlled the timing on your set-up, is that correct?
Andrew
Old 09-21-2017, 08:03 PM
DOOM's Avatar
Andrew
Exactly Andrew.
Mario
USCOLLISION
Old 09-21-2017, 08:35 PM
JKnight JKnight is offline
So....I think the next question might be...why?
Old 09-22-2017, 10:12 AM
DOOM's Avatar
That's a question that's never been answered!! As I said before I have been reading and learning about this system on my own . It frustrates the crap out of me when the people that say they know can't give you an answer. I learn new things every day in my business I have to deal with every make of car you can imagine. This is just another thing I'll read up on and learn trust me . But I've been talking with Holley and there looking into setting me up with a PRO BILLET distributor with all there new technology in it . They don't make the short version that I currently have in my car.
Mario
USCOLLISION
Old 09-22-2017, 11:27 AM
andrewb70's Avatar
Mario,
Make sure that whoever does the new distributer installation fully understands how to set-up a dual synch distributor. The distributor will offer both a cam and crank signal which are essential to full timing control and for sequential fuel injection...
Was there a cam signal to the ECU before (my guess is no...)? If that is the case, then your EFI was set-up in batch fire mode and not sequential mode.
I have a feeling that once everything is installed and configured correctly, it will be a different car.
Here is a video of installing a dual synch distributor for the Sniper EFI. Your process may have subtle differences but much will be the same.
Andrew
Old 09-22-2017, 06:17 PM
Ok, makes sense. Obviously I'm no expert either, I was just thinking there may be some functionality being left on the table given you have the Dominator ecu.
