Old 11-12-2017, 08:48 AM
Blake Foster's Avatar
Originally Posted by partsguy57 View Post
I have speedtech ( drives very nice very happy with) I used 3" stainless over the axle, mini tubed. I had to 45 the corners of the fuel tank.
Sent from my SM-G920R4 using Tapatalk
GREAT looking CAR!!!
Blake Foster
www.speedtechperformance.com
Old 11-13-2017, 05:45 AM
572Camaro's Avatar
Great looking car.
Are those wheels Budnik Tiller 5's?
Love the wheels.
Old 11-13-2017, 10:22 AM
BMR Sales's Avatar
Here are a few options for exhaust with our Torque Arm
Old 11-13-2017, 12:18 PM
bret's Avatar
bret bret is offline
Supporting Vendor
There seems to be some manic obsession with running the tailpipes over the rear rearend housing. I suppose if you are working with a vehicle that is at or near stock ride height then pipes under the rearend would be visible and look a bit out of place. When the car is lowered significantly [like most of ours] the rearend is buried up into the car so far that those concerns go away.
If you look at the rearend housing position at full droop, [after the new suspension is installed], the mufflers are still lower than that level, so you have to go "up" to run them under the housing. The point is, they don't hang down or look out of place, and the routing is MUCH easier. I have been running them this way on the 48 Hour Camaro [and Velocity before that] for years.
Since our triangulated 4 link rear suspension does not intrude forward of the mufflers, most any brand of X pipe/muffler will be fine...and it will be a fairly simple deal to make tailpipes.
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 11-13-2017, 07:14 PM
Motobrewmaster's Avatar
Motobrewmaster Motobrewmaster is offline
Hey Bret. Could you post a few pics for us please? I have your 4-link in my 69 Camaro and have it pretty low. Been trying to figure out where to run pipers back and am open to going under. Currently I am just dumping in front of the rear end and it drums horribly!
Cheers, Brew
Ps- have the full RT setup front to back including Tru-turn and a Tiger cage. Very happy with it all.
69 Camaro Owned since 1984.
Oh and Yes I am a Brewmaster.
Old 11-14-2017, 01:33 PM
bret's Avatar
Supporting Vendor
I am traveling to Scottsdale tomorrow for the Goodguys shootout...I'll try to get some images when I return next week.
Bret Voelkel
President
RideTech
Old 11-14-2017, 03:13 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Thanks for the order, Randy.
Here's a 69 we did a few years back, this one is obviously minitubbed but you see we went under the axle.
-Dale
SchwartzPerformance
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 11-16-2017, 07:13 PM
Thanks Dale & Josh,
I appreciate it. I too was wondering about the suspension resting on the pipes when at full drop. I also wondered how much it reduced the drumming? I assume that alot of the drumming in my car is caused by the exhaust reflecting in the axle well area as I currently dump mine just after the mufflers.
Thanks again for your insight. Brew.
