Old 04-26-2017, 06:34 PM
Forgeline Wheels's Avatar
Default Mark's Roadster Shop '63 Corvette on Center Locking Forgeline RS6 Wheels
Is this the evil older brother to Barry’s ’64? Mark’s sinister split-window ’63 Corvette was built by our friends at Roadster Shop. It’s powered by an LT4 and rides on a Roadster Shop FAST TRACK chassis, Penske coilovers, Baer brakes, the Forgeline Flush-Loc centerlock conversion, and 19x9/19x12 Forgeline RS6 wheels finished in Matte Black with a custom knock-off style center nut! See more at: http://www.forgeline.com/customer_ga...w.php?cvk=1897
Mark Schetter
Forgeline Motorsports
3522 Kettering Blvd
Dayton, Ohio 45439
O: 937-299-0298 x12
F: 937-643-0070
[email protected]
www.forgeline.com
Old 04-30-2017, 05:27 PM
Solid LT1 Solid LT1 is offline
Are those GM knock off centers with your winged nut? Just wondering what's involved in putting on a set.
Old 05-02-2017, 02:25 PM
Well, it's three things. When you order this setup, the wheels are designed to work with our Flush-Loc centerlock conversion kit. And the winged knock-off style nut is a new optional center nut (that sells for $300 each).
So to get this exact setup, you need to order:
1. One set of the RS6 wheels. (http://www.forgeline.com/products/he...eries/rs6.html)
2. One Flush-Loc centerlock conversion kit. (http://www.forgeline.com/products/ce...onversion.html)
3. One set of optional winged knock-off style center nuts.
From there, it's pretty easy. Just bolt the Flush-Loc adapter to your hub (it will already be precision-machined to fit your hub and the RS6 wheels). Use the supplied Forgeline drive pin lug nuts to mount the adapter to your hub and torque to your hub's usual torque spec. Then slide the wheel over the adapter and secure it with your knock-off style center nut. Torque spec is 300 lb-ft.
The adapters & nuts are threaded separately for left and right sides, so if installed properly, they should only get tighter while driving. But you'll notice that Roadster Shop also adds that extra bit of safety wire for a cool vintage look (and some extra peace of mind).
The RS6 will be machined with holes into which the drive pin lug nuts will slide, creating a perfect fit and a mechanism for forward torque transfer.
Mark Schetter
3522 Kettering Blvd
Dayton, Ohio 45439
O: 937-299-0298 x12
F: 937-643-0070
[email protected]
www.forgeline.com
Old 11-16-2017, 11:20 AM
Is this C2 split window enough to take your breath away? Mark’s sinister split-window ’63 Corvette was built by the craftsmen at Roadster Shop and graced the HP Tuners booth at the 2017 SEMA Show. It’s powered by a HP Tuners-tuned LT4 and rides on a Roadster Shop FAST TRACK chassis, Penske coilovers, Baer brakes, white letter tires, the Forgeline Flush-Loc centerlock conversion kit, and 19x9/19x12 Forgeline RS6 wheels finished in Matte Black with a custom knock-off style center nut! See more at: http://www.forgeline.com/customer_ga...w.php?cvk=1897
Mark Schetter
3522 Kettering Blvd
Dayton, Ohio 45439
O: 937-299-0298 x12
F: 937-643-0070
[email protected]
www.forgeline.com
Old 12-05-2017, 02:04 PM
conester2013 conester2013 is offline
Roadster shop does absolutely amazing work!! MAN I love these early gen corvettes!
