  #13
Old 12-12-2017, 08:44 PM
F'in mine's Avatar
I used this stuff from Lowes, cut it into snug pieces on each section, then taped the joints. Tonight's temp is 15 degrees F here in Toronto.
https://www.lowes.ca/foam-board-insu...eet-insulation
Another thing to keep in mind is when adding extra weight to the door sometimes the spring tension has to be adjusted.
1969 Camaro SSRS
Simon
