Old 12-10-2017, 09:35 AM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
I installed a smaller supercharger pulley and a larger idler pulley on the C6 - in this I go over how to install both.
Parts/Tools used:
Edelbrock Upgraded Tensioner: http://amzn.to/2jm02CM
Edelbrock 3" Pulley: http://amzn.to/2kqNe1v
102.5" Belt: http://amzn.to/2krdtoo
Thanks everyone for all of your support!
Follow me on Instagram: https://www.instagram.com/bonecrrusherss
Follow me on Twitter: https://twitter.com/bonecrrusherss
Like me on Facebook: https://www.facebook.com/bonecrrusherss
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 01-21-2018, 05:21 PM
Hello everyone!
I took advantage of the warm weather and took care of some maintenance items on the truck - and go over my latest updates.
If you are interested in the video - please watch it below.
Thanks!
Old 01-21-2018, 05:59 PM
In this video I go over cutting/creating the new fuel lines for the build.
I used -8 PTFE Hose for the fuel system - while this hose is a bit harder to setup - I won't have the gas vapor smell that happens with traditional stainless braided rubber hose - plus E85 won't break down this hose type.
Parts/Tools Used:
Fuel Line Quick Disconnect Tool: http://amzn.to/2z8gOxy
Evil Energy AN Wrench: http://amzn.to/2z84Eog
Air Powered Drill: http://amzn.to/2z8wgtP
Chisel Set: http://amzn.to/2C1bJFS
Pipe Cutter: http://amzn.to/2ASnGyg
NPT Tap: http://amzn.to/2z8u71e
Step Drill Bit: http://amzn.to/2C0cHSJ
PTFE Hose: http://amzn.to/2ASHNws
AN Adapter Fitting: http://amzn.to/2AD1XNS
45* AN Fitting: http://amzn.to/2ymutxk
90* AN Fitting: http://amzn.to/2ASHrWq
180* AN Fitting: http://amzn.to/2ym2yhg
90* AN Fitting to 3/8 NPT: http://amzn.to/2ASmNFV
Russell Fuel Filter: http://amzn.to/2Cc2rb2
Old 01-22-2018, 08:49 PM
I went to Corvettes at Carlisle this year looking for one part.
The part that I was looking for was a ZR1 hood.
A buddy of mine bought one of those hoods and put it on his Vette - and I thought it looked awesome.
So to help with aero and ventillation - I picked up a ZR1 hood and an ACS vented hood insert.
Also the ZR1 hood is made out of Carbon Fiber and is 1/3 the weight of the factory hood - so dropping some weight up front can't hurt either.
Old 01-23-2018, 06:12 AM
Its dyno time! How much Horsepower did the Corvette end up making?
Find out in the video!
Car was tuned at PCM of NC - http://www.pcmofnc.com/
Old 01-25-2018, 06:32 AM
I installed a Roto-Fab Radiator Cover for my Chevy SS.
If I had a stock SS - this would bolt on with no issue - but since I have an LSA supercharger, and a custom intake - the stock Roto-Fab radiator cover will not fit.
I ordered the bare cover - and notched it for my oil catch can.
I then primed and painted and installed the Roto-Fab Radiator Cover.
Tools/Parts Used:
VHT Engine Primer: http://amzn.to/2D1jmAe
SEM Trim Black: http://amzn.to/2mfZD5v
Old 01-25-2018, 06:46 AM
In this video I update the custom intake for my LSA swapped Chevy SS.
I wanted to get rid of the polished intake pipes - so I started sanding them with 320 grit.
I then primed and painted and installed the painted intake pieces.
Tools/Parts Used:
SEM Paint: http://amzn.to/2mGY2pt
VCM Fender Fill Plate http://amzn.to/2gnfVdM
Cowels Trim http://amzn.to/2iH7c6C
Old 01-25-2018, 06:55 AM
In this video - I continue the build by picking up a new Diff for the Corvette.
Old 01-31-2018, 11:28 AM
In this video I tear down the Z06 rear differential - and start repairs on it by replacing the broken housing cover/mount.
Tools/Parts Used:
Harbor Freight Press: https://www.youtube.com/watch?v=athkd...
Kent Moore Bearing Tool J42194
Diff Seal - http://amzn.to/2E7jM6u
Diff Passenger Side Cover: 19132920
Old 01-31-2018, 11:41 AM
In this video - I assemble and review the Harbor Freight 20 Ton Hydraulic Press.
Overall the install went pretty smoothly - I had to flip around the press I beam - and change the bolts on the bottom of the press since I put them in the wrong spot.
Hopefully these notes will help save you some time when you assemble your press.
Tools Used:
Harbor Freight #32879 20 Ton Press
