Old 04-21-2018, 04:47 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
As always, the fab is looking great, Ron! Where did you source the blue exh. insulators?
Thanks!
Ric
Old 04-22-2018, 04:26 AM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
They came from Speedway Motors, if I remember right they are available in a couple colors
Ron Schwarz
Old 04-22-2018, 07:09 AM
dontlifttoshift's Avatar
The blue ones last the longest. Seriously.
Donny
Old 04-22-2018, 07:21 AM
dhutton dhutton is online now
https://www.summitracing.com/parts/stw-exgro
Old 06-07-2018, 05:14 PM
57hemicuda's Avatar
The one time when high and tight on the cage was a bad thing. The engine is back so far, and the dash bar so tight, their was absolutely no room for wipers or linkage.
The AMX was originally equipped with vacuum wipers which was located about where the middle of the intake manifold is now.The engineering involved in making this happen was extensive. Used Fox body Mustang wiper motor because I thought it would be readily available, all the rest of the mechanism was custom. The park position was another challenge because the motor was designed for the PCM to park it.
A lot of work but the modern motor work way better then anything old.
https://photos.smugmug.com/Cars/AMX/...184410-640.mp4
Ron Schwarz
The Following User Says Thank You to 57hemicuda For This Useful Post:
65_LS1_T56 (06-07-2018)
  #886
Old 06-10-2018, 03:37 PM
57hemicuda's Avatar
Wipers done finally putting a firewall in it. a lot of little panels makes it super time consuming.
Ron Schwarz
Old 06-11-2018, 09:44 AM
Ron Sutton's Avatar
Originally Posted by 57hemicuda View Post
Trying to get exhaust buttoned up before the body work starts. Had to run one side of exhaust high to give myself watts link accessibility. Still have to figure what I'm going to do out the back of the tail pan.
The real issue though is where am I going to cram a rear sway bar. Real estate is at such a premium, I fear its going to end up inside the car.
I find I spend half my time designing stuff that is faster, lighter, stronger, safer, etc ...
and the other half of my time making stuff fit!
I feel your pain Ron.
Ron Sutton Race Technology
Old 06-12-2018, 01:42 PM
57hemicuda's Avatar
Closing large gaps make Mango happy. The bolt on body might have been a mistake. Way too time consuming, and it adds weight. Too late now, I'll have to finish.
Ron Schwarz
Old 06-12-2018, 01:56 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Progress looks awesome, Ron! All of the paneling work is coming out super clean!
http://bestofshowcoachworks.com
(760)480.0227
1969 Camaro - always broken GM Design winner
1965 Mustang - widebody fastback
2006 Coyote swapped "Rental Car"
Up next:
Steve's GT40
Old 06-12-2018, 06:49 PM
egoman's Avatar
egoman egoman is offline
[QUOTE=57hemicuda;678647]Closing large gaps make Mango happy. The bolt on body might have been a mistake. Way too time consuming, and it adds weight. Too late now, I'll have to finish.
Too bad about the bolt on being heavier. I am trying more of a tab on body that will allow freedom during construction and then be permanent at the end of construction. This is my inspiration!
The "Biggest" thing in motocross!
My build thread, Transcona, The dirty old Cougar!
https://lateral-g.net/forums/showthread.php?t=58877
