Old 06-22-2018, 03:41 PM
wyattroa wyattroa is offline
Some more
1966 chevelle - Basket Case
https://lateral-g.net/forums/showthread.php4?t=54993
Old 06-22-2018, 11:41 PM
Musclerodz's Avatar
Disc brake prop valves have seperate front lines. They was only tied together in a 4 wheel drum setup
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-23-2018, 07:05 AM
Is this correct? I plan to use the baer remaster with their prop valve and everything I have seen and looked at. It has one line going to the front and one brake line going to the rear. Ill be running manual brakes on the car.
Old 06-23-2018, 11:15 AM
Musclerodz's Avatar
The remaster prop valve has 3 ports. the standard prop valve only has an in and out for the rear line only
Mike Redpath
facebook page
Old 06-23-2018, 03:11 PM
WSSix WSSix is online now
The bolt head you cut down, what is it used for? I wouldn't use it honestlly. Can you find a button or pan head allen bolt that will fit in there?
Old 06-23-2018, 09:11 PM
I agree with WSSix.
Old 07-17-2018, 06:17 PM
Ill look into this!
Old 07-17-2018, 06:19 PM
Alright, got the floor on the drivers side all patched in and good. I am now going to knock out the trans tunnel. I am still unsure if I will go with a tko600 or t56. So I am going to cut the tunnel big enough for the t56 just incase. I really don't think I have a need for the 2 overdrive gears where I live. Here is how it looks as of now. I made a template and will transfer this over to metal. Hope to have this finished up this weekend. This way I can shoot some bed liner on the bottom of the car.
Old 07-19-2018, 12:53 PM
mfain mfain is offline
You are making great progress! Sometimes these projects can get a little out of hand. LOL
Pappy
Name:  66 Chevelle SS Skeleton.jpg
Old 07-19-2018, 08:10 PM
Alright, cut out a template to replace the trans tunnel. Still not sure what I am going to put in here, either the t56 or the tko600. Picked up a piece of 20G steel and Cut the template I made out. Tomorrow I plan on cutting the tunnel.
