Old 08-26-2018, 06:07 AM
Yelcamino's Avatar
Yelcamino Yelcamino is offline
It’s been a busy summer but I finally found some time to work on the Chevelle. Over the last few days I finished cutting out the floor and firewall.
10097 by Yelcamino, on Flickr
10100 by Yelcamino, on Flickr
Then I added in the two 2x2” rails to connect the front and rear chassis sections. More bracing will be added but this is just to get me started.
10101 by Yelcamino, on Flickr
10102 by Yelcamino, on Flickr
Once all that was done I put it on the ground for the first time in about two years! My curiosity was killing me so I scaled it just to see.
10103 by Yelcamino, on Flickr
Notice the driver side is heavier and the front bias is pretty light, but I’m sure the hood sitting on the roof skewed things a bit. Now that I have a baseline, I’m going to weigh it after each major change, such as the cage, engine & trans, etc. My goal is to not exceed 3400 lbs.
Well here it is…
10104 by Yelcamino, on Flickr
And here they are…
10105 by Yelcamino, on Flickr
Herb
1966 El Camino LS408/T56Magnum
1966 Chevelle 509/T56Magnum
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 08-26-2018, 05:50 PM
Yelcamino's Avatar
Here are some more pics from today...
10109 by Yelcamino, on Flickr
10110 by Yelcamino, on Flickr
10107 by Yelcamino, on Flickr
10108 by Yelcamino, on Flickr
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 08-27-2018, 05:14 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
It's looking great, Herb. It seems odd that the driver's side is so much heavier. That steering column and wiper motor must be really heavy, lol. Are you fabbing a complete new floor from scratch?
Ric
Old 08-28-2018, 08:50 AM
Yelcamino's Avatar
Thanks Ric! I didn't level the scales beforehand and the hood is on the roof, so I'm sure that skewed the results. At least I have a place to start so as I add things I can try to keep it balanced.
And yes, I'm building a new floor because I want to run a belly pan and keep everything above the bottom of the frame.
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 08-28-2018, 11:50 AM
Peter McMahon Peter McMahon is offline
Looks great! Would you be able to cut the rear frame off where it is horizontal and re weld it on at factory height so you can keep a stock trunk pan?
Old 08-28-2018, 07:05 PM
Nice update, Herb. Keep up the great progress.
Old 08-29-2018, 08:47 AM
1965_SS's Avatar
1965_SS 1965_SS is offline
Cut that car up! Looks great!
_________
1965 Chevelle SS
Project Build
Old 08-29-2018, 07:01 PM
Yelcamino's Avatar
Thanks! The rear frame rails are where they need to be for the suspension to be located correctly. On top of that, I'm not concerned about a stock trunk pan. This is going to be primarily a track car.
Herb
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 08-29-2018, 07:13 PM
Che70velle's Avatar
Glad to see your back at it Herb. The car is beautiful.
Thanks Dad!!
Old 08-29-2018, 08:37 PM
Ah, I see. I thought all the pick up points for suspension were forward of the horizontal rails and the rails were only for rear body support and bumper support Either way it’s an awesome car and you got a big set on you chopping out that floor! I would have to be hammered to get the guts to do that! Keep the updates coming
