Old 10-11-2018, 08:23 AM
sic7camaro sic7camaro is offline
Thanks for the reply, okay so it has a pcm out of a 2004 gto and a vaporworx fuel controller, and the pcm has a base tune in it.
Old 10-11-2018, 09:09 AM
dhutton dhutton is offline
What cam? Base tune from a 2004 GTO?
Old 10-11-2018, 03:17 PM
It’s a cam motion hydraulic. I had a base tune done for the 502 motor
Old 10-11-2018, 04:33 PM
I’m no expert but I think the timing is too advanced when cranking. I would get a better tune. Maybe one of the experts will chime in.
Old 10-11-2018, 06:49 PM
Che70velle's Avatar
I completely agree here. You need to get HP tuners/EFI Live scan of your cranking ignition timing, before you try to start the car again. It will likely break the starter boss off the block, if you continue. If it were an Oem block, it already would have broke. Check the timing first. I’ve seen this many many times.
Thanks Dad!!
Old 10-13-2018, 07:29 AM
572Camaro's Avatar
I watched the video.
My guess is you have too much ignition timing advance during cranking.
Please please put a timing light on and check during cranking.
My guess on your application is you want about 15-18 degrees btdc while cranking. That means you want 15-18 degrees between 0-400rpm.
I have a F.A.S.T. fuel injected 572ci 68 Camaro.
I completely shredded my flywheel when it backfired through the intake when I had cranking timing set at 22 degrees btdc.
Please don't do what I did! Ugh.....,
Keep us posted. You have friends you've never met who care!
Last edited by 572Camaro; 10-16-2018 at 08:07 AM. Reason: 28btdc, sorry.., not 22btdc
Old 10-14-2018, 11:06 PM
Thank you for all the help, I will definitely check crank timing this week.
I will let you guys know what I find with that
Thanks again
