Old 10-11-2018, 05:58 PM
Originally Posted by Blown353 View Post
Depends on the hubs and where you use them.
They will fit standard C5/C6 hubs with no issues, but if you run the heavy duty ZR1 SKF hubs they're not a simple drop in. The head of the studs will come very close to the OD of the SKF hub housing and you should grind a small flat spot on the stud flanges for more clearance.
If you run these on the rear hubs and also have a C6 e-brake setup, you'll need to grind another small flat spot on the outside of the stud to clear the e-brake actuator.
Not sure why ARP made the flanges on these studs so much larger than the factory 12mm studs.
Instead of modifying these studs to fit my SKF hubs and C6 e-brake I'm going to use the 100-7729 Mustang studs which have a smaller flange OD that clears the hub body and also have a flat spot already ground on them that clears the e-brake actuator, but you then have to open the stud holes in the hub to 0.609" for the mustang studs.
I looked up the 100-7729 ARP number and they are for a Subaru/Scion. The 100-7722 has a knurl diameter of.550 1/2"x 20 compared to stock studs knurl diameter is .509 . Are you staying with 12MM studs?
