Old 11-20-2018, 04:13 PM
Gmachine1911's Avatar
Alrighty, pulled the trigger on the PCM of NC fan harness and AC bump kit setup. Spoke with them on the phone and they sent me their instructions to check out prior to ordering. Other than the fact that you have to splice into a couple of the ECM connectors (which scares the crap out of me) this should be a slick setup. Even at that, the instructions are very detailed about where to make the connections both inside the engine fuse box and the ECM connectors.
Randy, I appreciate your input on the matter and certainly the offer of help! One question I have for you is that, if I understood PCM correctly, there's no need to run a trinary switch with this setup since the ECM/fans get the signal to activate or speed up directly from the AC compressor itself, correct? If that's the case then that will further decrease the wiring in the front of the car.
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
