broken vacuum port on ls3 intake
11-24-2018, 01:24 PM
dgroover4
Can the vacuum port on ls3 intake be replaced? Mine is cracked.
dgroover4
Find all posts by dgroover4
2
11-24-2018, 03:16 PM
gerno
Not sure if it can be replace. If you want to repair it I would try this stuff. I used it before with great results.
http://www.plastex.net
The Following User Says Thank You to gerno For This Useful Post:
dgroover4
(11-24-2018)
gerno
Find all posts by gerno
3
02-04-2019, 02:18 PM
gnx7
For N/A use you could even use JB Weld... for boosted you need a new manifold. Luckily they are cheap to buy.
Project:
1969 Chevelle
, alum 5.3, GTS76 turbo, Chiseled Perf A/W intercooler, Holley Dominator EFI, Davis TC, JRi coilovers, 14" brakes, T56 Magnum. CTS-V Recaro seats!
1993 Mazda FD RX-7
, built LS7, T56 Magnum, Holley HP, Davis Tech TC, 8.8" 3.73 Cobra IRS diff, DSS axles, Ohlins coilovers, big brakes.
CCW 18x11 front 315/30/18's and 18x12.5 rear on 335/30/18 RA1's,
2850lbs
gnx7
Find all posts by gnx7
Linear Mode
Switch to Threaded Mode
08:29 PM
