Old 12-05-2018, 07:53 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
It's called 2nd gear nibble, at least that's what the tech at AP told me when I called and ask about it. This is not uncommon in a new T56 Magnum. My T56 did the same thing when new and I asked the same question. I was told it gets better as the transmission breaks in. It does. I have around 10,000 miles now on my new Magnum and the shifting is dramatically improved. I still get a very slight 2nd gear nibble when I first start driving each day but once the transmission comes up to temp the nibble goes away. The only thing I would recommend is that you service the transmission with new ATF somewhere between 2000 to 3000 miles.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
The Following User Says Thank You to TheJDMan For This Useful Post:
69Camaro (12-06-2018)
