Old 12-05-2018, 08:13 PM
1965_SS's Avatar
1965_SS 1965_SS is offline
Originally Posted by SRD Art View Post
Lookin' good Todd!! Have you got a time frame to have the body on it?
No time frame...........
Man that rolling chassis looks sweet!! I bet you can't wait to set the body back down and button things up.
Yeah, can't wait to see it sitting down on the Forgelines!!!
_________
1965 Chevelle SS
Project Build
Old 12-05-2018, 08:21 PM
1965_SS's Avatar
Got the Ricks Tanks Vaporworx tank in. Huge thanks to Hector and Rick at Ricks Tanks. I had bought a Vaporworx tank from them 2 1/2 years ago when I was going to build my Chevelle with the stock frame. Fast forward to 2018 and changing everything, now I needed a tank for the Speedtech frame. He said "no problem, return the one you have and I will build the one to fit the Speedtech frame!" WOW, AWESOME!
_________
1965 Chevelle SS
Project Build
The Following User Says Thank You to 1965_SS For This Useful Post:
fleetus macmullitz (12-26-2018)
Old 12-05-2018, 08:31 PM
Awesome. Looks killer.
The Following User Says Thank You to Flash68 For This Useful Post:
1965_SS (12-05-2018)
Old 12-25-2018, 09:03 PM
64mali's Avatar
64mali 64mali is offline
Man, this is going to be a really cool build! I can't wait to watch it come together. I'm not sure if you have painted the underside of the body yet but I thought I'd throw in my two cents. That undercarriage is so clean I think it would look good if you did a nice satin black. After I stripped mine down I used an epoxy black sealer/primer them 3M Trim Black. It is really easy to spray yourself, durable, easy to clean or touch up, and has that factory look. You can see how I did mine in my build. I'm pumped on your ride.. keep it coming
The Following User Says Thank You to 64mali For This Useful Post:
1965_SS (03-12-2019)
Old 03-04-2019, 09:11 AM
1965_SS's Avatar
So I'm currently working on the wheel tubs. I'm using the ABC Performance 2" over stock wheel tubs. So far I've got the tub in place but not welded in. The tub itself needs to widened another 1.4" because my SpeedTech frame is a lot narrower than a stock frame. These tubs will have to be cut in half and a strip of metal welded in to get the correct width.
_________
1965 Chevelle SS
Project Build
Old 03-04-2019, 06:13 PM
Nice!
The Following User Says Thank You to waynieZ For This Useful Post:
1965_SS (03-05-2019)
Old 03-11-2019, 02:03 PM
67XR7's Avatar
67XR7 67XR7 is offline
Love how far this has come along!
1965 Chevelle, Pm me if interested in wheel tool rental
The Following User Says Thank You to 67XR7 For This Useful Post:
