Old 12-02-2018, 03:01 PM
syborg tt's Avatar
So you know that problem us guys on these boards have. You know when we something really cool something happens and all of a sudden we feel like we need it even if we don't. Okay, if your not that guy I am very very happy for you and when you have time can you please sit down with me and "Help" me be more like you.
When I was at Sema 2017 I of course stopped by Ride-Tech just to say hi and to see what was new. First mistake I should have just said Hi. Darren of course showed me the new 2nd Gen Camaro stuff and I was blown away. The new stuff they offered for the 2nd Gen was way cool and there will be plenty of stuff for me to upgrade to in the future.
Fast forward to summer and a quick email to Darren and the new R-Joint Arms are on the way to me for my rear suspension. Yep, I am excited and can't wait.
Nothing Like Christmas in the Summer
Houston we may have a small issue here. Not to worry we are going to figure this out. Since we offset the lower spring mount it puts the arm way to close to the spring pocket.
Upper Arms - No Problem Perfect Fit
Looking at possible moving the the arms over. However, if I move the arms over I will lose the tire clearance for the 335 rear tire set up.
In order to use the arms as is I will have to make some billet shims. For now I just used a few washers to test the articulations to see if the arms hit the spring pocket.
Bad news in stock location they hit and I am sure with the weight of the car they would move way more then I could get them to move on my lift.
marty-mj
Old 12-02-2018, 03:12 PM
syborg tt's Avatar
Okay, Since my goal was to have the rear differential back in the car by the end of the weekend it's going in today which is actually Saturday Sept 22.
What I love about this set up is its simplicity. It's so darn simple and yet it works so well.
Very important step...make sure you install the arms on the correct side so you can grease the them without having to take them out.
Need to get the back of the car up high enough so I can slide it under the car since I am doing this by myself.
marty-mj
Old 12-02-2018, 03:30 PM
syborg tt's Avatar
Minor dilemma here i need to get the rear end from it's current location to behind the my car which is on the lift.
Reality is I have to carry this thing about 15 feet and gently set it down on my car cribs.
Success, I guess all that working out I did when I as younger paid off.
Okay, this part sucked trying to get it on the lift while being hunched over.
Success !!!
In order to get the lower arms in I need to tip up the pinion
I moved the cribs which made the install much easier.
marty-mj
Old 12-02-2018, 03:42 PM
syborg tt's Avatar
Upper Arm Install should be simple right...Nope
Now that the rear end is powder coated there is a little less room and because of that the upper arms will not slide in.
Out comes the spreader which I have had for years and used so many time. It's perfect when you need to install a set of aftermarket lower control arms and they just won't slide in.
Finally
Still not sure why I went to my hardware bin.
I still can't believe I used all of these tools just to put the rear end in.
marty-mj
fleet (12-02-2018)
  #1175
Old 12-02-2018, 03:56 PM
syborg tt's Avatar
Can someone tell me why I didn't put the freaking gear oil in when it was on the ground.
Time to improvise
Look really really close and you can see the make shift funnel.
and why does your wife call you when you arms are wrapped up around a rear end and the other one is pouring gear oil in.
man does that not sound good.
marty-mj
fleet (12-02-2018), Sandro's 1969 502 Camaro (12-02-2018)
  #1176
Old 12-09-2018, 07:20 AM
syborg tt's Avatar
So right before Sema in 2013 Kenny had painted the BBT ground effects gloss black and we both agreed the gloss black
didn't work. So Kenny had a local vinyl shop wrap them with a carbon fiber vinyl. Fast forward to today they vinyl needs
to get retired.
I also need to thank the guys at Remes Autobody for painting these for me.
This time I went with a satin black which blends in well with the cars satin finish.
Looks much better.
marty-mj
Old 12-09-2018, 05:58 PM
Goosesdad's Avatar
Looks great Marty!
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
syborg tt (01-23-2024)
  #1178
Old 12-09-2018, 06:28 PM
syborg tt's Avatar
Need to shorten the exhaust by 1/4'' and also plan to to wrap the mufflers with the DEI Muffler Shield.
Mike's pretty darn good making a straight cut with a Sawzall
small learning curve here for both of us.
marty-mj
Old 12-09-2018, 06:51 PM
syborg tt's Avatar
Next Up put some DEI wrap on the tailpipes
This bike stand is really getting a workout.
marty-mj
Old 12-09-2018, 07:16 PM
syborg tt's Avatar
New Totally Stainless Sway Bar Links
The original set was a little short so we had to send them back.
Before
After
marty-mj
