Old 01-26-2019, 01:37 PM
Ripped's Avatar
Ripped Ripped is offline
The starter would not engage last night when I went to do my Friday workout.
Got a tow-start from the tow truck driver (thank goodness for a stickshift) and drove it home
I thought it might be the solenoid, but the wire just came off. I guess the heat cycles and soforth had weakened the push-on connector. It was really not gripping.
I took it off and used an eye terminal and the screw fastener, on the starter.
I don't want to risk having that fall off again. The car is way to low to want to crawl underneath at night somewhere (lol)
Old 02-09-2019, 03:35 PM
Ripped's Avatar
Picked up the rear brake kit today, hope to get it underway sometime next week
Old 02-10-2019, 11:07 PM
Ripped's Avatar
Lil bit bigger brakes
Old 02-11-2019, 02:56 PM
jarhead's Avatar
jarhead jarhead is offline
Nice difference
joe
Semper Fi
My 68 Torino
The Following User Says Thank You to jarhead For This Useful Post:
Ripped (02-12-2019)
Old 02-12-2019, 09:30 AM
Ripped's Avatar
Originally Posted by jarhead View Post
Nice difference
Thanks a lot. I am looking forward to a little bit better parking brake set up and hold as well.
I think that the braking upgrade I did previously was some of the best money I ever spent. It just gives a measure of confidence driving in traffic and on the highway, knowing you can stop, feeling that modulation and knowing you have extra braking capacity when needed.
Last night, after getting the OK from Baer, I had to drill the lug nut holes a tiny bit larger to clear the shoulder on the longer HD wheel studs.
it worked and there is a hub centric shim/washer to allow the rotor to be precisely centered, with the aftermarket 31 spline axles
So far so good, and tons of snow in the PNW so I can take my time doing the brakes, and not be tempted to drive lol
Old 02-14-2019, 10:30 PM
Ripped's Avatar
Winter nights make for tough motivation, but got both assemblies installed and calipers shimmed. Next big task is setting up the parking brakes. Different cables this time, so might need some adjustment to the electric brake assembly.
Once I get it all set up I'll bleed the rears and may flush the front system, for a fluid change
Old 03-11-2019, 11:10 PM
Ripped's Avatar
Brakes are breaking in and it was time for a quick cruise between the winter weather. My buddy's bike in front.
