Old 04-16-2019, 07:50 PM
LS7 Z/28 LS7 Z/28 is offline
PERHAPS THIS IS FINALLY THE LAST — but NO ——— the master cylinder bore may also have to be changed.... but we’ll wait until Jay runs the car with the Sutton spec on the 20th at LVMS.....
If you guys do end up changing the bore size, I’d love to know what you change to, as I’ve got the same calipers and likely the same size masters, since the bore sizes were suggested by Ron. The car is a ways from running, so it would help to change them and hopefully be closer to being correct right out of the box. Thanks for the tip on the pads as well. Hope you’re doing well Greg.
The Following User Says Thank You to LS7 Z/28 For This Useful Post:
GregWeld (04-17-2019)
Old 04-16-2019, 08:44 PM
jarhead's Avatar
jarhead jarhead is offline
I read allot of his (RS) posts when trying to figure out what to use on my rear suspension. He had me believing what he wrote.
OMG I am so glad I found Jay Weir. He explained to me, asked for measurements, sent information, called me, etc.
Although I haven't ordered my Speedtech stuff yet, I am so close I can taste it.
I may even be done before FE Rob
joe
Semper Fi
My 68 Torino
Old 04-17-2019, 12:40 AM
Gitter dun Joe!
Old 04-17-2019, 11:02 PM
FETorino's Avatar
FETorino FETorino is offline
You’re a Marine Joe. You should set the bar higher than that.
Rob in SoCal
Old 04-18-2019, 10:17 AM
DBasher's Avatar
DBasher DBasher is offline
Two things. One, OY had some worn out suspension components, I know because I have/had them. And B, RS is a crooked POS.
Honestly if OY was updated with some Mike Maier Inc components with some JJ prepped JRI’s it would have been equally as good if not better. IMO
