  #19
Old 04-29-2019, 09:53 AM
blitzer454 blitzer454 is offline
What was the voltage at the blinker wire when just the parking lights and engine are on with the marker lights still installed?
I'm confused as to why removing the marker lights would fix the LED dash indicator bulbs from lighting, unless they're not really LED bulbs. If they were incandescent bulbs then I would say that you have a bad ground in the dash that needs to be fixed but if they really are LED bulbs then that doesn't make sense as a LED bulb would block current from flowing in the reverse direction through the ground. So are you sure they are LED bulbs?
