Old 05-14-2019, 09:19 AM
SSLance's Avatar
SSLance SSLance is offline
Originally Posted by ScotI View Post
Your carb intake is a Perf RPM Q-jet correct? (I understand your new set-up above is diff vs the ProFlo-4)
My dual plane intake is a GMPP Dual Plane that came on the crate engine but I understand that Edlebrock manufactures these for GMPP and are the exact same as this one.
https://www.edelbrock.com/performer-...fold-2116.html
Lance
Old 05-14-2019, 09:36 AM
I don’t know what you’ve done to this thread but it’s become unreadable for me - the text is so tiny I can’t begin to see it....
Old 05-14-2019, 11:19 AM
ScotI ScotI is offline
Thanks for the info.
Old 05-14-2019, 03:21 PM
SSLance's Avatar
I blame Jody!! Or perhaps the iPad you are using...
I didn't change anything but for some reason the pics are showing up huge now when viewed on my PC which may be making the text font smaller for you.
Thanks for coming by and helping out today Greg. It helps to have reassurance from someone that has been there, done that to know that I'm at least on the right track with this project.
You look great BTW.
Lance
Old 05-23-2019, 09:38 PM
SSLance's Avatar
So, everything up top fits...
All the changes and new parts ended up playing pretty nice together. Next up, wiring...
I'm looking for a spark plug recommendation. Specs for the engine call for a AC Delco MR43LTS which I've used before but they are a pain around my headers. Recently I ran a NGK R5724-8 which was nice because it's shorter and easier to get around headers...but it is not available in resistor which I now need. Because one is a "marine" plug and the other is a "race" plug, I seem to be running into dead ends trying to find a shorty resistor plug. Heads are GM Fastburns. Any suggestions?
Lance
Old 05-24-2019, 10:40 AM
mfain mfain is offline
Looks great! Are you going to make Inde this weekend?
Pappy
Old 05-28-2019, 11:55 AM
SSLance's Avatar
Pappy
I did not make it up there...did you? Looked like a great weekend, really bummed that I missed it.
Lance
Old 05-28-2019, 12:00 PM
SSLance's Avatar
Last Sat was 3 weeks from the start so I missed that deadline...Lord willing and the creeks don't rise I should be close to ready to fire by the end of week 4.
Engine itself is pretty buttoned up, spacer mod worked great, headers and mid pipes are back on with new graphite gaskets that fit great, V Band clamps and O2 bung worked out great as well. We'll see if there are any leaks once it makes heat...
Up top got all of the vacuum lines arranged and hooked back up. I have a bit of an issue with the AC line and the new raised radiator hose that I didn't plan on, it'll be fine for now but this may be the straw that humps me into finally getting my 34 year old lines replaced properly...
New starter wire, new alt charge wire and new engine to battery ground wire are in place on engine side and all ECU harness leads are at the battery area. Next up is wiring up a relay center and making all electrical connections to relay center and battery posts. Also need to run a power wire to the coil and tach signal wire to the gauge module.
Then once that is all done, making some fuel lines and installing the tank...then we test everything and make heat...
Gave these a new coat of Eastwood's high temp ceramic coating since they were out. last coat lasted over 3 years and still looked pretty good.
O2 port put the top of the sensor a little closer to floor than I would have preferred but it'll be okay. Someday I'll redo the whole exhaust properly and fix it then.
That's it for now...y'all are up top date...
Lance
Old 05-28-2019, 06:53 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Looks good, Lance!
Ric
Old 05-30-2019, 02:29 PM
SSLance's Avatar
Got my relay box bracket fabbed and mounted along with my positive and negative distribution lugs.
It's behind the headlight in front of the core support right ahead of the battery. Pretty protected yet should be pretty easy to access as well if needed.
Pinned the wires to the fan relays to get my feet wet, went pretty well I think. Now onto the fun stuff...
Hope this works... **fingers crossed**
Lance
