Old 06-26-2019, 09:15 PM
syborg tt's Avatar
When Mackenzie and I were visiting Kevin & Kelle at V8 Speed & Resto Shop we saw these bad ass fender
covers that they were using on customer cars.
Some of you may have noticed the belt was run incorrectly so I figure I would fix it.
All better now
Looking forward to installing this.
Initially the plan to run just an air filter as I still have no clue if I want to run an intake tube.
We are going to need to space the crossbar just a little bit.
marty-mj
fleetus macmullitz (06-27-2019), Roscoe03 (06-27-2019)
  #1212
Old 06-26-2019, 09:19 PM
syborg tt's Avatar
I am getting really good at taking this car apart.
Exhaust coming out again.
headers also
back in the shed.
marty-mj
Old 06-26-2019, 09:21 PM
syborg tt's Avatar
Time to take the dash out and this is going to be fun and fairly easy.
marty-mj
Old 06-26-2019, 09:24 PM
syborg tt's Avatar
Time to pull out the towels as the WOOL carpet itches.
I have a pretty cool idea for the duct work based off of the lower dash.
Next Up the Dash Pad and Steering Column
Twenty Minutes later the dash is removed.
marty-mj
Old 06-26-2019, 09:31 PM
syborg tt's Avatar
Next Up I plan to clean up the harness and thin things down a bit.
Since I have friends at Pro-Tek Powder Coating I plan to have this bracket powder coated.
I have found To-Do lists help keep me on schedule.
This will be step one as it is no longer needed.
When I started removing the harness I made sure to mark everything and take a bunch of pictures for reference.
Column is fully removed and will be going to it's new home soon.
marty-mj
  #1216
Old 06-26-2019, 09:33 PM
syborg tt's Avatar
More parts for the next phase of the car.
marty-mj
  #1217
Old 06-27-2019, 05:14 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Very nice work Marty,great detail
The Following User Says Thank You to tubbed69 For This Useful Post:
syborg tt (06-27-2019)
  #1218
Old 06-27-2019, 07:14 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Food for thought on the air cleaner. Now you're sucking in hot radiator air, with an intake you'll be sucking in cooler air.
Instagram- camaroaj
The Following User Says Thank You to CamaroAJ For This Useful Post:
syborg tt (01-23-2024)
  #1219
Old 06-27-2019, 09:08 AM
fleetus macmullitz's Avatar
Hardest workin’ man on lat-g?
The Following User Says Thank You to fleetus macmullitz For This Useful Post:
  #1220
Old 06-27-2019, 09:10 AM
Goosesdad's Avatar
Sweet!
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
