Old 07-04-2019, 07:16 PM
aany001's Avatar
aany001 aany001 is offline
Default 18x9 wheels what tire size?
Need some help with my 69 camaro with a stock sub frame. I resized my front 18” rim to 9” wide. What tire size are you guys running? I was running an 18x8 with 245 40 18 and 5 1/8” back spacing. I was running 3/4” spacers up front and removed them and widened to a 9”. I had no issues except minor turning radius loss which I adjusted with my steering stops. So with a 1” wider rim removing the spacer and adding 1/4” negative camber I think I should be right where I was before. I’m thinking of going with a 255 40 18. Im looking for a flat sidewall with no bulge or stretched look. I hope all this makes sense.
Thanks in advance.
Steve
Old 07-07-2019, 07:05 PM
markaaron80 markaaron80 is offline
I went with a 275-35-18 on my 18x9 fronts. Look perfect to me.
Old 07-07-2019, 07:13 PM
aany001's Avatar
I mounted 275 35 18 Pirelli P Zeros but found out they are built 1/2” wider and that’s what I’m not liking. I used my buddies setup with 18x9 rim and Falken 275 35 18 and they fit PERFECT!!! ☹️
Old 11-04-2019, 08:24 PM
SoloTech SoloTech is offline
On the Tire Rack web site, click on "specs" for a particular tire model and it lists the "Rim Range" for each tire size.
Old 01-23-2020, 11:09 PM
Pete68's Avatar
Pete68 Pete68 is offline
Im running 275 on 18x9
1968 Camaro
2003 Boxster S
http://www.cardomain.com/ride/2543199
