Old 06-14-2019, 01:18 PM
Jr's Avatar
Jr Jr is offline
Default X-pipe mounting
Hello all,
I'm very close to getting the exhaust done, and I would like some thoughts on mounting an x-pipe the same way Blake did on his 72 nova.
Old 06-14-2019, 01:34 PM
Build-It-Break-it's Avatar
I saved the same picture of Blake's nova to duplicate the exhaust set up on my camaro. Looks like a tight fit tho. Mock it up and move the rear suspension around without springs to check for clearance.
Ahmad
Ahmad B
Old 06-17-2019, 10:19 AM
Jr's Avatar
Jr Jr is offline
I’m more concerned with mounting the x pipe they way he did. I don’t want to restrict flow/hurt hp and tq
Old 06-18-2019, 12:11 AM
Sorry I meant to put x pipe as I was looking at the exhaust...... I meant the x pipe looks like a tight fit.
Ahmad B
Old 06-29-2019, 05:09 AM
I seriously doubt any negative effect on power would be great enough for you to notice. The effect on the sound of the exhaust system by not having the balance pipe would be greater. That's just me though. I don't like the sound of dual exhaust without a balance pipe.
You can always go with an H pipe if that would be easier.
Old 07-09-2019, 08:23 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Funny, I'm exactly the opposite. I hate the sound of an X-pipe dual exhaust.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 07-10-2019, 08:30 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default Torque Arm + X-pipe = Tight Fit
Here's how we're doing mine with the BMR torque arm... only way to get an X-pipe to fit between the trans cross member and the front mount for the torque arm.
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 07-10-2019, 09:48 AM
dontlifttoshift's Avatar
I'm no engineer and I didn't even stay at Holiday Inn but I think all those cars with sideways Xpipes would make more power and sound better with a simple H pipe.
Change my mind.
Donny
Old 07-10-2019, 11:12 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Change my mind.
Agreed.
Old 07-11-2019, 06:39 AM
ilikeike's Avatar
ilikeike ilikeike is offline
I had a 3" X pipe on my first gen, I installed a SpeedTech torque arm this Spring, I went with a 3" H pipe. with the same Magnaflow mufflers the change in sound was very obvious to me. The X pipe had a smoother sound and had more of a howl at rpm, the H pipe is choppier more of a muscle car sound I guess, but still sounds good. I liked the X pipe sound better but the custom install wasn't worth it to me.
